HTT Stage IV how-to and impressions
Originally Posted by Begle1
I was under the impression that a Stage IV's all had wastegates?
All they do is upgrade the compressor? I did not know that...
that's all they do if that's all you buy...
they also sell the exhaust housings...wastegated or not...
Greg
I'm sure by 40psi the drive pressures with the 12cm are through the roof. I'm thinking about putting the 18.5cm housing back on or rigging up the wastegate to work, and wastegating it at 33-35psi. I'd really like to set up a drive pressure gauge just to see what it looks like at different boost pressures, since I'd like to stay close to 1:1.
Oh, and my tranny hates me now!
Originally Posted by jbs007
How much was the kit? I hd looked into sending my turbo to them.
Update: I got a video of the sounds (the camera picks them up well at <12psi boost) and the EGT's and boost.
http://media.putfile.com/Stage-IV-compressor-upgrade
Sweet vid! Cameras still can't do that sweet sound justice though, can they? FWIW, I've got a drive pressure gauge hooked up and with a heavily ported 12cmWG housing, I'm right in the 1:1 neighborhood all the way to the wastegate opening @36-ish pounds. I'd still like to try the 18 again (sold it
) just to see if the SOP is any different...my trucks actually feels faster with the wastegate wired open....
Awesome video clip, Gman! Yours picked up the sound a lot better than mine did.
Is there a general rule of thumb with drive pressures and housing sizes? Moving from a 12cm to a 14cm would allow how much more max boost at the same 1:1 drive pressure? I know it's not set in stone and varies for each truck, but is there some sort of general guideline one can use to estimate it?
Gman
I'd try the 18.5cm housing out, the 12cm housing is quite small for you especially if you dont have the wastegate hooked up, and i can imagine drive pressures are through the roof!
With the stage 4 and the 18.5cm housing i can hit about 36 PSI. When the boost kicks in it's up to 34 right away then slowly climbs for that last 2 PSI.
Give it a try and see what you think of it. It's a little laggy down low but you should be able to tune your fuel for that.
Sammy340
Sammy340
Originally Posted by sammy340
Gman
Sammy340
Sammy340
. And then I'll need a torque converter, and then a locker so I spin both rears, and then injectors, and then... oh wait, college.
You talked me into it! I ordered the Stage IV kit from HTT yesterday. It is gonna be nice to get my egt's below critical temperature for a change.
That is a well done write up with pictures, which by the way will be on my bench when I break the first nut.
