How the heck do you northern guys do it
Old Feb 1, 2011 | 06:02 PM
lenuelmp23's Avatar
This dam truck if freezing cold. It gets warm when it idles with heater on but once you go down the road it's like some one turned the ac on. Temp gauge goes down cold air come from vEnts
Old Feb 1, 2011 | 06:04 PM
schamran's Avatar
winter front helps. So does pulling out the HVAC box and resealing it.
Old Feb 1, 2011 | 06:18 PM
7horn's Avatar
Winter front, plug it in, good boots (for you and the truck ), warm clothes, and electric socks that plug into the cigerette lighter.
Old Feb 1, 2011 | 06:26 PM
dieselJon's Avatar
Check your antifreeze level. My crown vic would get ice cold air at speed but nice and hot at idle. The coolant bottle was empty. Fill it up and all was good to go.
Old Feb 1, 2011 | 06:28 PM
BILTIT's Avatar
Winterfront. Mine wont warmup much until i drive it, get on the highway and its nice and warm.
92smokin blacky's Avatar
synthetic oil, cardboard in front of radiator, plugging truck in, and lots of #1 fuel.
Old Feb 1, 2011 | 06:52 PM
440trk's Avatar
sounds like your thermostat is stuck open. My 91 will darn near melt you out of the front seat, if you let it.
Old Feb 1, 2011 | 06:53 PM
BearKiller's Avatar
We have four drivable Cummins trucks at the moment, two are non-I/C radiators, one is an I/C, and another is my Ford with the HUGE Ford diesel radiator that is at least four-times the capacity of the Dodge units.
On a 10* day, all four of these trucks heat right up and will soon run me out of the cab they get so warm --- without winter-fronts/cardboard installed.
I do keep the coolant systems in A-1 shape, which is likely a big help.
Old Feb 1, 2011 | 06:56 PM
BearKiller's Avatar
I agree.
I had my thermostat get shrapnel from a failed water-pump caught in it such that it was held open and I like to have froze until I figured it out.
Old Feb 1, 2011 | 07:00 PM
Thiss's Avatar
Blow out your heater core and make sure your coolent is toped off. I would second the thermo and I also run carboard when I am on the east side.
Old Feb 1, 2011 | 08:22 PM
SORTIE's Avatar
also make sure your coolant loop isn't leaking under pressure (mine was, but I never saw it under the truck). the heater loop runs off the top 4" of the radidiator and if your antifreeze is too low - NO HEAT
Old Feb 1, 2011 | 09:34 PM
bandedgandr's Avatar
I use a winter front and removed the stock cooling fan replaced it w/ an electric one out of a ford taurus... Nevr runs except in the summer... Comes up to temp in -20 in 10-15 minutes of high idle or driving.
Old Feb 1, 2011 | 09:45 PM
Moparbubba's Avatar
plug it in plug it in...
i leave mine plugged in over nite let it idle 15 mins before i go to work and its warm
Old Feb 1, 2011 | 10:40 PM
BearKiller's Avatar
If it is an A/C truck, that heater-hose shut-off valve gizmo could be stuck in the closed position.
Get the engine up to operating temperature and feel how warm the heater-hoses are.
Old Feb 1, 2011 | 10:53 PM
Jim5870's Avatar
-check the left floor vent for air leakage, some folks seal them up permanently.
-the various air doors in the HVAC box have been known to sieze up.
