How Far on a Tank of Fuel?
Old Mar 22, 2006 | 08:15 PM
nailhead's Avatar
Question How Far on a Tank of Fuel?
How far do you 5-spd owners generally go on a full tank of fuel? Here is why I ask: I pulled up to the pump the other day day with the needle just bouncing off E, so I figured I was pretty much out of fuel & would be pumping about 30 gallons. After 15, it was plumb full; no more could be shoehorned in. Since this fuel gage seems to be pretty close to useless, I figure I'll just fill up by the odometer like I do with my motorcycle, but I want to get a sampling of how far a similar truck will go.
BTW, I got 17 mpg in mixed city/hwy driving on that trip. I'm really starting to be glad I bought this truck.
Thanks for any help,
Chris
Old Mar 22, 2006 | 08:24 PM
edwinsmith's Avatar
My last fill-up was at 485 miles. The Low fuel had just come on. It took 25 gallons.
Old Mar 22, 2006 | 08:26 PM
I don't like to see the fuel gauge below half so I refill about every 250 miles.
Old Mar 22, 2006 | 08:27 PM
nailhead's Avatar
OK, that's more like it. My odo said 267, & like I said that gage indicated I would be sucking fumes soon. Thanks!
- Chris
Old Mar 22, 2006 | 08:34 PM
chuxtruk's Avatar
If I let it go that long, 600 miles and I'm looking for fuel. On my 93, when the low fuel light comes on, they say you have 20% remaining, which would work out to 6 gallons (about 120 miles). I've ran it all the way to nearly empty, according to the guage, but I've never put in more than 27.7 gallons. Last time I checked my mileage I was getting 22.5 mpg. Adjusted valves, clean air filter etc and I'll get my 23.7 like I have since buying it new. I think there's a bit of a cushion there unless you let the needle get on the low side of the E mark....then you better have your tennis shoes on. Chuck
Old Mar 22, 2006 | 08:42 PM
nailhead's Avatar
A 15 +- gallon cushion? Thats pretty plush...
- Chris
Old Mar 22, 2006 | 08:48 PM
RATCHET's Avatar
Filled up yesterday at 590 miles, took 27.6 gals=21.3 mpg and this after i put 235/80/16 tires to make the speedo accurate.Fuel light was on for 3 days. I figure 120 after light comes on as well. -RATCHET-
Old Mar 22, 2006 | 08:55 PM
csramsey640's Avatar
400 miles and im getting fuel. sometimes less, but I idle my truck frequently(to run my winch) and usually only drive it with a GVW of 15,000 lbs and up
Old Mar 22, 2006 | 09:10 PM
ds1rider's Avatar
400 city and 500 hwy. I love the highway.
Old Mar 22, 2006 | 09:51 PM
silverbullet02's Avatar
During the summer when truck was bone stock I got just over 700 miles...706 I think. Ended up putting 28.x gallons in, averaged around 24.5 that tank. Once took a trip (bone stock) and it was around 250ish miles and mostly 55-60mph cruising, got 25.5mpg...I was impressed. And again, this was in the summer. For some reason it doesn't get as good a mileage now
Brian
Old Mar 22, 2006 | 10:22 PM
timb's Avatar
You guy's are making me feel real bad here. I know it's an auto, but I get about 335 out of a tank. I think sumpins wrong here. Oh by the way, I have gotten as little as 265 also.
Old Mar 22, 2006 | 10:47 PM
delar60's Avatar
Tank Miles
Our miles are as follows on 97 SLT, stock as far as we know:
424,301,257,200,167,177,369 -- have yet to pump over 20 gallons. Overall average is 17.265. Sure will be glad to get to summer and find some good #2 fuel, this winter blend sucks.
Old Mar 22, 2006 | 11:13 PM
ratat98's Avatar
I usually clock around 450 in town, but on my trip to kentucky in the fall, I easily made it over 600 before refueling and got 21ish mpg the whole way! I love diesels!!
Old Mar 22, 2006 | 11:20 PM
DBF's Avatar
DBF
I usually run out of bladder capacity long before I run out of fuel. As long as I'm stopped, I fill up. If not, 550 is easy if I'm not towing.
DBF
Old Mar 23, 2006 | 07:43 AM
old dog's Avatar
REALLY old dog
Talking
1992 350 2w dulie club cab w sleeper OD lock switch topper onback ,pulling car & trailor , just came back from a trip to KY 1,000 + mi. got 17 MPG X 30 gal tank + 510 if you run her dry, but like some one else said bladder needs to be made gladder before then so i always fill up then.
Claude
