how do i get it to smoke
Old Nov 16, 2009 | 06:32 PM
  #31
adam greene's Avatar
its a auto so i dont want to make much more power till i get the tranny worked on.
Old Nov 16, 2009 | 06:41 PM
  #32
Benjamin b2's Avatar
take the spring out of the afc, if it dont smoke at low end before it builds boost, then look into cutting the collar off your fuel screw
Old Nov 16, 2009 | 06:46 PM
  #33
it wont hurt it if the spring is out? also when i done the pump mods my spring is green and orange are all of them like that and also the pin had already been turned so i no someone had been it it before. but everything else was stock. also advancing the timing what will that do?
Old Nov 16, 2009 | 07:21 PM
  #34
no advancing the timing wont help much, and your fine pulling the spring out, if you want pull the little poly washer off the fuel pin first and see if that helps.
Old Nov 16, 2009 | 08:44 PM
  #35
TIMMY22's Avatar
Originally Posted by adam greene
still no smoke, turned the pin to the deep side to the front, power screw 1 turn smoke screw 2 1/2 and starwheel 1 turn still no smoke ***.
Wow, Something is up. Mine smoked a little before I touched the pump and after I did what you said above, I could fill an intersection with smoke that would take 30 seconds to clear up depending on the wind.
At night, I can drown out the headlights in my rear-view of the car behind me.
Old Nov 17, 2009 | 04:15 PM
  #36
1bad93's Avatar
thats what i was scarded of, on a first gen an auto ant gona break as easlie as a 2nd gen but it will also hold you back badly cause of the loose converts that dodge put on them. this is more than likly why it isnt smoking because its not putting the load on the motor because of the converter slipping. i would suggest getting a converter.
Old Nov 17, 2009 | 05:02 PM
  #37
Stihl's Avatar
My truck when it was stock didn't smoke at all with pin turned deepest, power screw 1/4 turn from runaway, starwheel/smoke screw both down either. Try making sure you have full travel on your accelerator, there should be a sticky about it somewhere.
Old Nov 17, 2009 | 07:15 PM
  #38
Rampage1967's Avatar
Why would anyone want to watch $2.85 a gallon fuel float away as a big cloud of smoke?? Aren't tickets for pollution and being a safety hazard kind of expensive too??
Old Nov 17, 2009 | 08:19 PM
  #39
who cares we just want smoke lol
Old Nov 17, 2009 | 08:23 PM
  #40
rebel_horseman's Avatar
Muted User
Those of us in Free America don't have to worry about crap like that. And if the OP or anyone else for that matter wants to cause nuclear winter in their wake, that's their prerogative. There's a time and a place for it...there are some times when you just want to fart a big cloud out of your pipe for one reason or another.
Old Nov 17, 2009 | 08:59 PM
  #41
93 12v's Avatar
Bury your smoke screw as far as you can, and put your starwheel all the way down, keeping track of the # of turns so you can back track if you need to. Don't mess with the power screw anymore until you have gauges. This will get you what you're looking for. Also, maybe the reason we have so varied responses to pump settings is due to location and elevation. We went on vacation in '08 for Gustav, and all my tires were set at 80 for towing, even the spare. When we got to Arkansas at the campground, all my tires were 12lbs over and my spare blew up in the back of my truck! Just a thought.
Old Nov 17, 2009 | 09:03 PM
  #42
ill try it, could there be something wrong with the pump not flowing enough fuel to get it to smoke idn just asking, the mods i done to it helped a bunch
Old Nov 18, 2009 | 03:15 AM
  #43
i got the last two "diffective exhaust" tickets dropped because of tecnicality of the ricleman scale and the last one i try to get stuck for was defective equipment and neg driving, those by the way didnt stick either. its a load of horse "beep"
Old Nov 18, 2009 | 04:56 AM
  #44
SmokemS's Avatar
well either you like it or you dont....but no matter what your opinion is.....everyone is gonna do what they wanna do.....i personally like it makes me feel happy inside
Old Nov 18, 2009 | 11:00 AM
  #45
ow dont get me wrong, it makes me feel great when im down in the morning and i can never pass up smokin out a full city block
greenrig
Apr 25, 2008 03:55 PM
PK
Oct 19, 2003 10:28 AM
jbs007
Jul 8, 2003 01:29 AM
97CTD
Mar 17, 2003 08:14 PM
