how do i get it to smoke
i got a 93 d-350 160k how do i get it to smoke, ive turned the smoke screw 2 1/2 turns starwheel 1 turn and power screw 1 turn untill it hit the coller. id just like it to smoke a little it wont do nothing now.
Yep, Smoke makes heat and that ain't good. Get a pyrometer installed first, then turn the AFC pin so deepest part is looking to the front. Cut the collar off the fuel screw and turn it in some and advance the timing 1/8 inch more at the match mark. The tech section has a lot of really good information. Be careful and don't short cut safety.
Some of you folks may not like this comment but we all know excessive smoke is the result of incomplete combustion and wastes fuel. It also put a target on our trucks as polluters which could bring on the wrath of "get them off the highway" from those who currently have a large influence on EPA legislation. Out of sight - out of mind may be a better mindset.
Now back to the OP's question...one thing that really made my truck smoke significantly was swapping the stock fuel pin for a DennyT Stage II pin. Now I can run as clean or as dirty as I want. Yuppies in their Mercedes usually find out just how much 'moke I can belch out.
I agree with trebor and 92'1stgen, even though I can blow smoke with the best of em I choose not to fog out every living thing in sight and cropdust every intersection I go through
I don't do smoke everywhere either, but it sure smokes if I get on it. All of the modded 1st gens smoke when horsing around. I have yet to see a truck with over 275 hp not have the ability to roal the smoke out. I have tuned mine to limit as much as possible but no way to get rid of all of it.
