How Big Is A Valve Cover Gasket For My 93??
I just purchased one for when I adjust the valves and I'm kind of surprised by the size of the thing....
Should it be about the same size as the valve cover (like on an old small block Chev)?? Or is this 4 inch by 5 inch kind of square piece of gasket the whole thing?? Thanks! Chuck
It's the whole thing. You need 6 of them. But unless yours are leaking or otherwise damaged you shouldn't need to replace them. Under the pretty Dodge cover there are 6 individual valve covers you can take off 1 at a time if you like. Set the valves cold.
Here's complete instructions to adjust the valve lash.
http://www.dodgeram.org/tech/dsl/val.../12_valve.html
Edwin
Edwin
ok, sweet. I did check advance, for $4.44 a piece fer Fel-pro's. I'll have to try n find a Cummins shop around here, I need em badly. Maybe this weekend, alomg with a valve adjustment. Thanks guys!
Thanks you guys! Upon reading the description further I find now that I didn't pay good enough attention and got SOAKED on this one. I figured a valve cover gasket is a valve cover gasket but NOTHING has ever been easy working on this truck, so it figures that I buy 1 and need 5 more. There's no leaks currently but who knows after the valve adjustment?? Live & learn....and never again.
Chuck
Chuck
Chuck
Chuck
Edwin
I just ordered mine form Miller Dodge today for 7 and change a piece. However, I stupidly forgot to ask if they were Cummins supplied, and grey.
oh well, needs to be done anyway, so this weekend I'll be doin the valves and gaskets!
