Houston We Have Smoke!
Old Feb 17, 2005 | 04:59 PM
FNJ's Avatar
FNJ
Got the lock the lock ring off the fuel screw (amazing what u can do with a Dremel) Screwed the the screw back in smokes but not alot. The only thing is I cant get the idle to come down to a respectable grumble. The idle screw is backed all the way out. Pleasee help.
Old Feb 17, 2005 | 06:20 PM
dzpoorjr's Avatar
You have to compromise-back the fuel screw out a turn to get idle down!
Old Feb 17, 2005 | 06:59 PM
Is the idle screw touching the throttle arm? You sometimes have to do a little grinding because the arm hits the pump. The linkage may also be stopping the arm before it hits the screw.
Old Feb 17, 2005 | 08:08 PM
ChrisLib's Avatar
My cruise control cable is like that. With the cable on, the throttle won`t return all the way. I`ve been too busy to really look into it so I just took off the clip and popped the cable off for now, can`t use cruise around here anyhow.
Old Feb 17, 2005 | 10:26 PM
boiler-rat's Avatar
That idle screw is a fun one ain't it! I had to put a little piece of wire in that hole in the end and then run the lock nut all the way against the wire to turn it. Haven't figured out what do to if I ever have to go the other way!
Old Feb 17, 2005 | 11:51 PM
rebal's Avatar
I used 2 oring picks and a screw driver to help turn that bugger idle screw
Old Feb 18, 2005 | 09:01 AM
ARedetzke's Avatar
What would happen if you simply re-indexed the linkage on the throttle shaft? I know you could reduce idle speed this way, and it would get you back into the area where you could adjust it by turning the low idle screw, instead of grinding off the linkage. What I'm not sure of is what effects, if any it would have on the high end. Any thoughts?
AJ
Old Feb 18, 2005 | 10:13 AM
FNJ's Avatar
FNJ
I did the same thing with the picks and the little hole at the end of the idle screw wow wat a pain that was! Yes wanna diesel the idle screw is backed out all the way. The 10mm bolt on top is the throttle index I tried to adj it but it made no difference . Its to cold out to day to fool around with it and Iam not driving the truck anyway so thank you all for the help John
Rednecktastic
Nov 10, 2010 09:49 PM
ctrials
Dec 11, 2007 08:30 AM
Gene007
Competition / Pulls / OffRoad
Apr 16, 2006 08:38 AM
BigBlackDodge
Apr 26, 2004 03:02 PM
BigBlackDodge
Nov 28, 2002 06:26 PM
