Heater switch
Old Feb 18, 2005 | 08:51 AM
Craig93's Avatar
Heater switch
Does anyone know if the blower motor circuit goes through the heat or defrost selector switch? Reason I ask is I only have low speed on heat and defrost, no high speed, yet switch to vent and I have high speed. I see that if the switch is on high and you select 'off' the motor speed cuts out so....anyone have a wiring diagram that shoes this?
TIA,
Craig.
Old Feb 18, 2005 | 10:04 AM
edwinsmith's Avatar
Here's a diagram for my 89.
Hope it helps.
Edwin
Old Feb 18, 2005 | 10:10 AM
Craig93's Avatar
Thanks!
Old Feb 18, 2005 | 10:14 AM
rebal's Avatar
have you changed the switch yet ? mine did that 3 time since i bought the truck and each time i changed the switch it stopped but the real cause for the switches going out on mine was a fan motor that was damaged at the factory (had a big dent in the side) i have since changed the fan motor and the proplem has not come back
Old Feb 18, 2005 | 10:21 AM
Craig93's Avatar
Hmmm....so your fan would work on high except in heater and defrost mode?
92smokin blacky
Sep 1, 2010 09:55 PM
smokeyram
Aug 21, 2009 06:19 PM
Barryn
Jul 14, 2008 09:30 AM
SPLnut
Dec 31, 2007 11:27 AM
redramnc
Mar 28, 2005 06:58 AM
