Higher Geared Rear-End?
Old Mar 8, 2006 | 12:25 PM
90firstgen's Avatar
My pickup has the 3.54? rear end. I'd like to replace it and put an even steeper geared one in. Looking for a little better fuel mileage etc... Does anyone know of any? I would like something right around a 3.00 And how many dollars would this run me? Thanks for any help.
Old Mar 8, 2006 | 12:35 PM
apwatson50's Avatar
Many automatics came with a 3.08 ratio.
Old Mar 8, 2006 | 02:04 PM
G1625S's Avatar
There's at least one in the classifieds. 3.07:1
Old Mar 8, 2006 | 02:05 PM
Begle1's Avatar
Another thing you could like into is a gear splitter/ auxilliary over- or under- drive. It's a much more flexible solution, but more expensive.
Or you could always get bigger tires.
Old Mar 8, 2006 | 03:29 PM
Redleg's Avatar
You would have to change the entire axle and get a 3:07 if yours is 3:54. The parts are not interchangeable. No point in doing it unless your was bad and somebody gave you a 3:07 axle, because the important parts can't be replaced anymore.
Old Mar 8, 2006 | 04:00 PM
90firstgen's Avatar
Hey Begle1, I saw on your info that you have a tach. Not trying to throw the thread off track but how did you go about installing that?
Old Mar 8, 2006 | 05:20 PM
Begle1's Avatar
Our 1990 trucks don't have tach sensors built in from the factory, so we have to get more creative.
My tachometer, which is the most popular one available for our trucks, is the Autometer 2888 (I guess now they call it a 2697, though...).
http://www.autometer.com/cat_gaugede...earch&gid=3239
Mine came with a electro-field-sensor thingie that you stick to your alternator with a big radiator clamp. The alternator sends out electric pulses at a certain number of times every engine RPM; after you attach the sensor, you use an optical tachometer to find you engine RPM while it's idling, and then you use a **** on the back of the tachometer to adjust the engine speed to that level. So if the optical tachometer reads 800 RPM at idle, you turn the little **** until the tachometer says 800 RPM, and then the reading is accurate all the way through the power band.
Since Autometer seems to have restructured their parts database, I don't know if the alternator sensor still comes with the tach. Call whoever you order the tachometer from to ensure that it isn't sold seperately.
Here is the sensor that clamps to your alternator.
And here is the tachometer as I installed it on my dash.
And now, back to the scheduled programming...
Old Mar 8, 2006 | 05:42 PM
AFAIK, the correct part # for the alt. tach is 2888, or 3788 if you want a white face model.
Excellent post, Begle1.
Old Mar 8, 2006 | 06:44 PM
Begle1's Avatar
Ahh, it was 2888...
But their website says it's 2697 now, so who knows?
And Dave the First Gen Messiah said I made a good post! Woo-hoo! Does that mean I'm a useful member now?
Glad to be of service...
Old Mar 9, 2006 | 07:42 PM
90firstgen's Avatar
Originally Posted by Begle1
Ahh, it was 2888...
Well that post was definately useful! Thanks for all the help guys
Old Mar 10, 2006 | 04:35 AM
bgilbert's Avatar
Do you have a 5 speed or auto? If auto you already have 3.08 gears.
Old Mar 10, 2006 | 10:22 AM
90firstgen's Avatar
It's the 5-speed.
Old Mar 10, 2006 | 04:22 PM
Ahh, it was 2888...
D'oh! I'm not gonna argue with AutoMeter.
Begle1, I'll settle for minor prophet status, say on the level of Ezekiel or Hezekiah.
Deezil
22
Jun 9, 2014 10:12 PM
69fj2.5
Jun 14, 2009 12:26 PM
Nsomniac05
16
Jun 23, 2008 06:25 PM
jerry007
Oct 28, 2004 08:24 AM
13
Mar 29, 2003 11:46 AM
