help with removing turbo exhaust housing
Old Mar 26, 2007 | 04:01 PM
90dodge's Avatar
ok, i am taking my turbo exhaust housing off, well trying. i have taken off the 4 backing bolts and plates. but that lil sob wont come off. looked at the survice manual and it dosnt look like any thing else keeping it on there. but it wont come off, not even a budge.
i used the PB blaster, vice, still nothing.
any help
Old Mar 26, 2007 | 04:11 PM
gman07's Avatar
It's tough, especially after it's got a lot of miles on it. Try beating on it with a hammer; don't try to use the hammer to knock the housing off, but hit "inward" around the housing to try to knock it loose. Then you can use a hammer to drive evenly around the housing trying to knock it off, but make sure you spin the shaft while you're doing so to make sure nothing binds. I had to heat the housing with a torch to get it to come of the center section.
Old Mar 26, 2007 | 04:20 PM
Lil Dog's Avatar
A good piece of 2X4 and a 2lb sledge. You have to work it off slowly by giving it a good bump. Work in a criss-cross pattern with fairly good blows to the housing. Each blow I spin the turbine to make sure I don't pinch the wheel with the housing which could bend the shaft. It takes a bunch of hard blows to get it goin, but its only about 1/4" after it starts and its off.
Old Mar 26, 2007 | 05:03 PM
SPINPOSI's Avatar
I just went though the same problem here....
https://www.dieseltruckresource.com/...d.php?t=141938
jd4440
Feb 1, 2008 12:09 PM
Tiara3100
13
Jan 1, 2008 02:23 PM
Matt Lambrech
Aug 5, 2007 04:19 PM
90firstgen
Mar 28, 2007 04:47 PM
HOHN
Dec 7, 2003 02:07 PM
