Heater/defroster controls
Old Dec 2, 2012 | 11:17 AM
bill-d-c's Avatar
On my 93, the heat comes out through the dash vents only. You can push the defroster button but that doesn't change the air flow. Nothing comes out of the floor vents either. Checked the sticky but couldn't find anything helpful. Checked the service manual, it says that if the actuator fails, it will fail in the defrost position. Just not sure where to go from here.
Thanks,
Bill
Old Dec 2, 2012 | 01:39 PM
j_martin's Avatar
Thanks,
Bill
Could be a combination of failures, linkage gummed up, etc.
Good place to start would be to be sure you have vacuum to the control set.
Old Dec 2, 2012 | 06:39 PM
bill-d-c's Avatar
Do I need to pull the controls out of the dash to check that?
Bill
Old Dec 2, 2012 | 10:28 PM
gyman98's Avatar
Check for vacuum on the line that goes to the check valve/filter. That is your supply. It's under the dash, the lines come through the firewall near the heater hoses
Old Dec 3, 2012 | 06:23 AM
TIMMY22's Avatar
Looks like an electrical plug...kinda clear w/ red,green,black,blue etc. Unplugs real easy.
Old Dec 3, 2012 | 08:31 AM
bill-d-c's Avatar
OK, thanks. I'll check that.
Bill
Old Dec 3, 2012 | 09:58 AM
Jim5870's Avatar
Another possibility is that the moveable blend and defrost doors inside the HVAC box have seized up, I've seen it happen.
CaptainKelley
17
Jan 3, 2010 01:52 PM
SmokinFive9 4x4
Apr 4, 2005 03:17 PM
INJECTOR JACK
May 10, 2004 09:14 PM
Nuttymopar
Nov 12, 2003 12:56 PM
patriot pearl blue
Dec 28, 2002 12:44 PM
