Headlights
Old Jul 26, 2023 | 12:40 PM
Cowboytrader21's Avatar
Headlights
I replaced both headlights and the headlight switch. Everything works except the drivers side headlight is about half the power of passenger side light and doesn't seem to change with dimmer switch. What up? I need the headlights to work as designed. What is wrong? This is a 1991 Dodge w250 full size single cab truck.
Old Jul 26, 2023 | 03:36 PM
1st thing I would do is check all the grounds.
By check them I don't mean just look at them, but clean up the contact points and make sure the wires are not corroded badly.
Old Jul 26, 2023 | 03:47 PM
Headlights
What grounds specifically? and where are they located exactly?
Old Jul 26, 2023 | 04:56 PM
Fordzilla's Avatar
Try running a redundant ground from the driver's side headlight and see what happens......Ben
Old Jul 27, 2023 | 05:39 AM
Rug_Trucker's Avatar
5 Year Member
I know there is a ground on the top of the radiator support driver side. 2 wires there.
Old Jul 29, 2023 | 10:55 AM
Success!
I checked the plug in on the headlight and found one of the 3 prongs pushed to the side and not connected. I bent it back in place and plugged it in and Voila lights working perfectly. Thanks to all who offered solutions to this problem.
Old Jul 30, 2023 | 10:49 AM
5 Year Member
What aggravates me about these old style bulbs is they lose their seal where the terminals go in. I tried RTV. It peels and leaks. I am going to try the Permatex that is resistant to gasoline. I call it black berry juice, forget the real name.
Old Jul 30, 2023 | 02:51 PM
edwinsmith's Avatar
Or you could just put wiggling the connectors on your checklist with oil changes and other PM.
Old Jul 30, 2023 | 03:05 PM
5 Year Member
They just leak water into the bulb, then they die.
Old Jul 30, 2023 | 05:38 PM
edwinsmith's Avatar
I bought a pair of Hella lights with replaceable bulbs. They came with a rubber gasket thinghy that fits over the back of the assembly and seals the reflector of the light with the pins of the bulb. There is a hole in the reflector to allow moisture to escape. I have had very little trouble with them other than one of the pins in the plug got loose and required wiggling.
Kruang
Apr 17, 2017 06:07 PM
stock12valve
Apr 2, 2017 07:26 AM
Rickcher
Jan 10, 2011 05:14 PM
mopar luva
Apr 18, 2010 09:19 PM
