Head Lights wouldn't
Old 01-04-2007, 09:58 AM
Boatnik's Avatar
I was having problems keeping the running lights on so I decided the Headlight switch was getting tired. I installed the new one and was a little concerned that the plug going to the switch had had a meltdown at one time or the other. I replaced the obvious loose lug connectors and put the dash back together and everything tested sat. That is until I tried leaving for work about an hour before sun up. The headlights wouldn't stay on. So back into the dash I go to dig out the switch. The part of the harness plug that was left in tact had a weak connactor and in the process of twisting the wires around to reinstall the switch it must have loosened up. I was a half hour late but I got my lights back. NAPA sells the light switch harness repair part for 41 bucks so I guess I will need to go back in there and do it right. Maybe this one will last longer since I'm using relays.
Old 01-04-2007, 10:07 AM
Chrisreyn's Avatar
Do you mean the plastic connector itself? If so do you have the part number? NAPA here said they didnt have it........
Old 01-04-2007, 08:17 PM
Boatnik's Avatar
Tell your parts guy to get with it. NAPA-Echlin EC159 connector. I asked the guy here to pull a new head light switch to make sure it does fit. I'll probably solder it in this weekend. I don't care for lugging or butt splicing a high load center or a critical part.
keithw1975
08-16-2006 05:34 PM
iweb
06-22-2006 07:00 PM
biglar
01-12-2006 09:07 PM
MR HYDROSEED
06-16-2005 09:28 AM
Jbolt001
06-20-2003 07:34 PM
Quick Reply: Head Lights wouldn't
