HE351CW Clamp
Old Mar 9, 2013 | 07:56 PM
1972RedNeck's Avatar
HE351CW Clamp
I just picked up a HE351CW today. I will be getting THIS flange. What clamp do I need? I won't be running the cast elbow.
I found THIS clamp, but am confused about the HX40 part. What should I order?
Old Mar 9, 2013 | 08:17 PM
93flatbed's Avatar
I do believe those will work together. Well at least the way I read it. What are you doing about exhaust? If you are at all handy with a welder and cut off wheels you can do it cheap. I don't think I have much over 150$ in my whole set up, but my repurposed drive line stack was free. Yeah I said it an aluminum 5" drive line out of a Chevy truck delivers my smoke signals.
Old Mar 9, 2013 | 09:00 PM
I already have a DE 4 inch system. From my understanding, the above clamp hooks a HE351 flange to a HX40 flange, correct? I need a HE351 to HE351 clamp.
Old Mar 9, 2013 | 09:05 PM
93flatbed's Avatar
You need a 351 to diamond eye exhaust clamp... Is you diamond eye a 4"? I'd assume you could cut your down pipe flange off and weld the one you mentioned to it the clamp it to the 351. But I honestly don't know. I'd call them on Monday to get your ducks in a row. That's 100ish$ on a whim.
Old Mar 9, 2013 | 09:09 PM
The exhaust system is on the truck attached to the stock H1C. I will cut the existing flange off and weld the above flange on. I just need a clamp to attach the exhaust with the new flange to the turbo.
Old Mar 10, 2013 | 08:57 AM
bump
Old Mar 10, 2013 | 12:54 PM
BILTIT's Avatar
Use the clamp you linked above, its the one i used.
Old Mar 10, 2013 | 02:22 PM
You used the HE351 flange for the pipe?
Old Mar 10, 2013 | 04:30 PM
BILTIT's Avatar
Yup,
This flange welded to the 4" DP and this clamp to connect to the turbo.
http://www.dieselautopower.com/produ...pterflange.htm
http://www.dieselautopower.com/he351...51%20clamp.htm
jesussaves
0
Apr 21, 2009 12:04 PM
benjimatt
Mar 19, 2009 12:16 PM
sdubfid
Jan 24, 2009 10:41 PM
PaulDaisy
Sep 13, 2008 08:42 AM
Bad Ramer Jamer
Dec 27, 2007 09:32 AM
