Haulin my tractor seen 1500 in the pyro?
Old Aug 23, 2009 | 09:19 AM
  #31
Mike T.'s Avatar
JD730
I've said this before and I'll say it again, for all you guys with the timing advanced a little and towing with sustained egt's in the 1200F range, even though your temp looks safe the extra timing keeps the heat in on the piston and rings longer and you can scuff a bore.
What should be the max egt with a 1/8 timing bump?
Old Aug 23, 2009 | 03:12 PM
  #32
Jer12377's Avatar
From: North Haven,CT "Living in occupied teritory" & Barton,VT
Originally Posted by RollinCoalSmoke
We don't have any hills to speak of down here. What we have is some long grades nothing compared to other parts of the country but these grades we have may be 3 to 7/8 miles from start to finish. Knowing where they are I'll ease into my ole rides and get steam built up and work the daylights out of the engine. Don't be scared to run against the govenor that's what it is on there for, when the pyro starts going up toasty back off or drop a gear, if you drop a gear mash on it and just repeat the above till you top out the hill. The only thing to worry about is the EGT, don't lug, don't be afraid to run against the governor. I've seen diesels in irragation setups that run against the governor for days with no problems. Ya just gotta get over the gasser mentality and stand on the skinny pedal and drive by your gauges, let the engine work and let the gauges tell you what to do next. I'm not raggin on anybody but the ole diesels just have to have a different driving style to perform like they should.
Its like learning how to drive all over again. I guess what do I have to loose, two of my favorite things to do is work these trucks and work on them. Till the governor kicks in it will be. But you are right, gassier mentality is what I've got. As soon as those R's get up there, I swear my grandfather is still sitting next to me YELLING "SHIIIIIFT"!!
Old Aug 23, 2009 | 03:28 PM
  #33
Jer12377's Avatar
Originally Posted by deerslayer1979
Ok here are some pics of my truck loaded down and Dads D600 kinda loaded
I have some more of us pulling but those can go somewhere else.
DS79
NICE SET UP. How long is that trailer? Mine has a 24' deck and yours looks like it could fit both my truck and trailer on it. Is that a IH 656? We have one that looks just like it. Couldn't see your truck real good in those pics. My favorite look for these trucks is the reg cab W350s and the ext cab W250s.
Old Aug 23, 2009 | 10:05 PM
  #34
deerslayer1979's Avatar
The trailer is actually my uncles, he just lets us use it. I think its a 32ft trailer but Im not sure. All I know is that it is really freakin heavy, as you see it in the pic I was 24,500 GVW. I didnt even have the weights on that tractor! Dad was around the same I think, maybe even heavier. The tractor on my truck is an 856 aka "The little 8" My dad had his newly purchased 756 on his. We didn't do to bad at the pulls I ended up with a 7th (even though I went 304ft!) and a 2nd in the 10500# class. My bro was middle of the pack with the 756. had a couple good hooks but we havent got it figured out quite yet, next year we'll have that one running strong too! As for the truck I like it a lot, The body style and the bed just work together. Still needs the rims painted and the body waxed but otherwise its perfect for what I wanted.
DS79
Old Aug 24, 2009 | 06:36 AM
  #35
JD730's Avatar
Originally Posted by Mike T.
JD730
I be careful with sustained temps above 1150F when towing.
Old Aug 24, 2009 | 10:08 PM
  #36
14racing's Avatar
I don't have an intercooler and i never really see much over 1200* towing around my 4020 which is much heavier than what you've got there. Like most of the others said don't be afraid to wind er up.
Old Aug 25, 2009 | 07:54 AM
  #37
RollinCoalSmoke's Avatar
14racing what does the ole 4020 weigh? I had one many many years ago and we were discussing it yesterday. Couldn't remember if it was around 12 or 14,000. Thanks
Old Aug 25, 2009 | 06:31 PM
  #38
14racing's Avatar
You know i've never weighed it but im sure its at least 10k. I'd really like to go weigh it sometime.
Old Aug 25, 2009 | 06:51 PM
  #39
I was thinking it weighed 12/14,000 with water in the rear tires and a full suitcase of weights up front but I just don't remember.
Old Aug 25, 2009 | 09:54 PM
  #40
I think an open station 4020 w/o fluid in the rears and a wide front should be around 9-10K. Not 100% but I know of at least 2 that I pull against in the 9500 & 10500# classes.
DS79
ckt_santiago
Dec 26, 2018 03:55 PM
Patrick Campbell
Jun 4, 2004 04:41 AM
Mopar_Mudder
Nov 11, 2003 02:18 PM
97Dually
13
Jun 14, 2003 12:21 PM
