grid heaters don't work
Old Jan 19, 2013 | 07:01 PM
ponch russ's Avatar
my 93 grid heaters quit working. when you turn the key on i have no wait to start light no check engine. if you turn past on to start the W.T.S light and water in fuel light comes on if you let it sit with the key on. sometimes the relay on the drivers side fender will start to click rapidly and then turn on the grid heaters.if you just start the truck the wait to start light flashes all the time.
I have checked all the the grounds and cleaned them. tested all the fusible links.have power on one side of the small wires on both heater solenoids. power to one big wire on top of both solenoids. Thanks in advance
Old Jan 19, 2013 | 08:32 PM
JD730's Avatar
Had the same thing happen on my 93 a few years ago, the PCM that sits behind the battery went bad. Started with the relay clicking rapidly when cold and got worse until it stopped working.
Old Jan 19, 2013 | 09:00 PM
ponch russ's Avatar
so is the PCM the computer
Old Jan 20, 2013 | 07:24 AM
JD730's Avatar
Correct.
Old Jan 20, 2013 | 06:03 PM
Dave F's Avatar
I see your truck is about identical to mine. I think the computer runs the AC, charging sys, cruise, grid heaters, and maby the speedo. Everything is pretty easy to wire to manual except the speedo. I just dont know about the speedo.
Old Jan 21, 2013 | 03:26 PM
rockmike's Avatar
I found that wire the PCM grounds to operate the grid heater and rigged it on a toggle switch to ground and it works! external volt reg is taking care of charging duties.My a/c dont work and no cruise.I modified my gauge cluster and run and older cable drivin speedo head in the cluster its within 2-3 MPH and most important to me is I have a working Odometer...FWIW the gauge cluster looks OE you cant tell Ive screwed with it
Old Jan 22, 2013 | 10:20 AM
barrytransport's Avatar
you should change your toggle switch to a momentary push button just in case you bump it and it stays on. Nothin worse then coming out to a dead battery from the grid heaters staying on
Old Jan 22, 2013 | 11:26 AM
rattlerbob5.9's Avatar
Good idea because it could be even worse when stuck on and the wiring catches fire = no more truck!!
Old Jan 22, 2013 | 12:56 PM
Dave F's Avatar
was this one of the wires coming off of the solenoids? Crafty solution to the speedo!
Old Jan 23, 2013 | 06:58 PM
ponch russ's Avatar
Checked the PCM from the info in the sticky. The PCM is bad I will order a replacement. Thank you all for the info. I'll let you know how it turns out.
Old Feb 1, 2013 | 06:32 PM
ponch russ's Avatar
Its about 50 degrees outside and moved my truck and everything works again. The grid heaters work and I have AC and cruise. The battery is charging now and everything seems to work. We cant figure out why it would work in the warmer weather. Have any ideas of what it could be?
Old Feb 1, 2013 | 08:11 PM
j_martin's Avatar
50° is about the high limit. A few degrees warmer and it won't cycle.
Also, it's the manifold temp that's being read, so if it is warming up outside, the temp that's being sensed might be lower.
CaledoniaOutlaw
Feb 16, 2015 10:13 PM
00Dog
May 11, 2006 12:23 PM
806 Southern In
Mar 12, 2004 06:11 AM
Hoss
16
Oct 20, 2003 09:13 AM
Cumminsdude
Mar 25, 2003 11:58 AM
