heater controls
Old Jan 27, 2013 | 08:04 PM
flipper197129's Avatar
heater controls
on my 93 dually. i am having issues with the vents not changing from derfrost to vent or floor. stuck on derfrost. does anyone have a diagram of vacuum lines in dash an outside at firewall. as it feels like it has no vacuum.
Old Jan 27, 2013 | 08:22 PM
Jim5870's Avatar
Sometimes the doors in the HVAC box will seize up. take off the glove box door,
then you can get your hand on the vacuum linkages, check for frozen linkages
Old Jan 27, 2013 | 10:43 PM
Jim Lane's Avatar
Check the small hose at the brake booster check valve.
Old Feb 1, 2013 | 10:48 PM
Chrisreyn's Avatar
I had that issue..
was a bad check valve.. but I also had brake issues as well..
Old Feb 2, 2013 | 01:29 AM
The main control assembly on the heater/AC control can warp from heat and age. Then they crack open and do not allow the vacuum to be re-directed properly.
But start at the booster, and work your way along all the lines to the interior. You might find a small hole in one of the lines, from rubbing against something...I had this happen to me.
NGA Ram
Nov 15, 2006 05:00 PM
HydraulicGuy
Nov 9, 2006 01:20 PM
SmokinFive9 4x4
Apr 4, 2005 03:17 PM
INJECTOR JACK
May 10, 2004 09:14 PM
patriot pearl blue
Dec 28, 2002 12:44 PM
