Gov. spring and 4.10 gears
Old Apr 9, 2007 | 02:15 PM
triton0708's Avatar
91.5 I/C 5 speed, 4.10 gears. Will the spring be a big change, or will the 4.10's still be a limiting factor?? And I'm waiting on warm weather to put on my 12cm WG housing also.
Old Apr 9, 2007 | 02:43 PM
Ace's Avatar
Ace
Originally Posted by triton0708
...or will the 4.10's still be a limiting factor??
Only thing 4.10s will be limiting is your fuel mileage. That gov spring was the first pump mod I did to my truck and the improvement was nothing short of amazing. Any 1st gen with a 5sp should have this mod at or near the top of the list of things to do.
Old Apr 9, 2007 | 02:44 PM
A_port93's Avatar
i have 3.54s and a manual and when i installed the spring just a week ago or so i noticed a big increase in performance not so much at the higher end but the stiffer spring makes it pull harder all the way through the band. i am not sure why you wouldnt see the same result having 4.10s
Old Apr 9, 2007 | 04:45 PM
gomerpile's Avatar
well sounds like a modification i need to do. is there a place on the internet i can get it from, because the closest diesel distributer is 50-75 miles away, and fuel would cost more than the spring itself
Old Apr 9, 2007 | 04:56 PM
triton0708's Avatar
Good good, thanks as always guys!
Old Apr 9, 2007 | 05:00 PM
A_port93's Avatar
www.piersdiesel.com
21$ shipped to gresham, oregon (for me) they sent it in a small regular envelope style piece of mail so i dont see why it would vary too much for you in tennesse
16$ part
Old Apr 9, 2007 | 07:15 PM
ofcmarc's Avatar
Piers lists the spring for $16 and a 3000 RPM governer spring kit for $125. Do I need the kit or can I get by with just the spring and reuse the seals?
Old Apr 9, 2007 | 07:24 PM
whereswaldo250's Avatar
It looks intimidating to put it in that is why I have been putting it off
G1625S's Avatar
I've had my pump top on and off several times using the same gasket with no problems. the 125 dollar kit is for p-pumps
Old Apr 9, 2007 | 07:32 PM
ofcmarc's Avatar
Cool, Thanks
Old Apr 9, 2007 | 09:57 PM
A_port93's Avatar
i am a complete idiot and i did it...so i figure if an idiot can do it you should be alright...honestly i had no prior experience to working on pumps other than pump mods(external) and me and a friend (not an idiot) figured it out in a pretty smooth fashion. i did stay at a holiday inn express though so thats what i accredit my ability to...
89f150
Sep 16, 2008 05:04 PM
93beater
Feb 28, 2007 09:28 AM
DISLSMOKE
Oct 13, 2006 04:58 PM
fishin fever
Mar 13, 2006 06:46 PM
papaw92
Mar 27, 2005 12:20 PM
