Got my IC and intake horn!!!!!
Old Oct 19, 2005 | 01:45 AM
pwrtripls1's Avatar
I got a slightly used 2nd Gen IC for $68. It looks great and is good shape, only a few bent fins even. The intake horn was about $90, but its new so I can live with that. Now all I have to do is come up with some pipe and bends and couplers. Any ideas of what to use here? How much power should I gain on an over fueled non IC first gen with cool air?
I guess next should be HTT III and POD's
PS screw the tranny, let it burn!!!!!! I have better plans there.
Old Oct 19, 2005 | 03:31 AM
bgilbert's Avatar
Mucho power! Did you have the IC pressure checked before buying it??? I wouldn't touch a used IC with any damage, even the nice looking ones leak. As far as the pipes, if you could find oem in a junkyard, cut/weld it to fit. I used two sets to make mine. All 1st gen parts. I'm sure the junkyard is out of the question since you bought a new intake horn for $90 . I'll see what I can find this weekend at my local yard.
frostie's Avatar
You got a great deal on that air charge cooler.
unfortunately that cooler has huge piping. I would guess 3 1/2 inch. you need to go to a wrecking yard and get the boost hoses. they are 3 1/2 on 1 end and 3" on the other, with a 45degree angle.
the side going to the intake manifold shoud not be too hard.
the side off the turbo will need some work. you may need a 91.5 to 93 fresh air housing on your turbo and a 94 up adapter to fit the air piping.
You are on the right track for more power and lower EGTs.
good luck
Old Oct 24, 2005 | 07:58 AM
pwrtripls1's Avatar
I'll probibly make my own pipes and bends, so I can keep the flow as high as possible.
Is $90 good or bad for a new intake horn?
Old Oct 24, 2005 | 08:42 PM
MrHappy's Avatar
I have a ATAAC from a '99 on mine.
I used the factory 2nd gen Dodge piping and lower boots. (I used silicone hose for the 2 straight ones.)
Also, a 2nd gen elbow on my PDR HX35.
I used a 2nd gen intake horn, and had to only shorten the pipe (intake manifold side) a little to make everything fit.
Now for the POD's I have sitting here.
yelloz28
29
Jul 27, 2010 09:08 PM
93-12Smoke
Mar 15, 2009 10:15 PM
bullboy85
May 7, 2008 10:41 PM
dieselcarpenter
Mar 26, 2008 05:08 PM
natlchamp2k4
Mar 13, 2007 05:47 AM
