Good Or Bad
Good Or Bad
is this good or bad worth it or not http://cgi.ebay.ca/Cummins-6BT-5-9-M...455QQrdZ1QQcmd
Not what you want to do. That would cause bad turbo lag and overload the cooling system. The engine that turbo came off is a 5.9 liter that makes 330 HP @ 3,000 RPM and can do it for hours on end. Turbo lag is not something they worry about in that application, having the turbine housing crack due to long-term overheating is. They have a cooling system of unlimited capacity at their disposal as well.
Turbos run on heat energy. Cooling the turbine housing dumps a bunch of that energy into the cooling system instead of converting it to rotary motion and making boost.
Thank you.
