Bad day just got REAL bad!
Old Jan 31, 2003 | 08:25 PM
doomgaze's Avatar
Ok, so I went looking for Premium Winterized Diesel to fill up my truck just about an hour ago. I couldn't find any places that had it, so I settled for fueling up at Fuel Mart.
I guess I have never experienced the pumps that do not stop on their own when the tank it full. Now, I don't know if there is such a thing, or the **** thing was broken... but nevertheless, diesel went all over my truck and onto the floor. I was not a happy camper, knowing the things diesel can do to paint.
Then, going out of the gas station, I took a wrong turn and pulled into a driveway to turn around... almost slid into a telephone pole in the process. Then I put it into 4 wheel drive to get out of the snow and was on my merry way.
But that's only where my fun begins...
Driving home, I experienced one of the scariest things I've ever had the "pleasure" of experiencing. Shortly after I got on the interstate, I got up to about 65pmh and my truck started to shake. And this was not any shake... this was an EXTREMELY violent shake. So violent I could not keep it on the road. Luckily, no one was coming so I pulled over and stopped.
Ok, nothing seemed to be noticably wrong after I stopped. I decided to tell myself it was just the interstate that was VERY bumpy in that area. (Although, I know in my heart that NO ROAD is THIS bumpy.)
So I stepped on the accelerator and began my journey home...
I get up to about 65-70 again and IT HAPPENS AGAIN! This thing was shaking so violently, it was not even funny. I have never been shook so hard in my life before (except for about 60 seconds before that!). So I pulled over YET AGAIN and stopped and put it into park. I sat there for a minute to collect myself. I had no idea what to do. So I took off again. This time I did not accelerate to over 55 and it did not happen again on my 10 minute trip home.
I parked in the dorm parking lot and did a visual check the best I could in the dark. Everything seemed to be alright. No puddles of anything on the ground... nothing smoking... etc. I didn't get a real good look though because it's pretty dark outside...
What happened!? Does anyone have any ideas?? Was it a fluke? Was the road really that bumpy? Did my transmission blow? Did the fuel cause it? I need some major assistance here!
While on the way home, I tried to notice if the TC was locking up or going into the last gear while going 55mph... but I didn't get the chance to. It usually is done shifting around the 45-55mph mark... so I don't believe its my transmission... but I could be wrong. (I hope not though)
Old Jan 31, 2003 | 08:50 PM
phox_mulder's Avatar
Re:Bad day just got REAL bad!
I believe you experience the "death wobble".
Dodge 4x4's owners have experienced this.
Check your trackbar.
I wish I had a picture, since they are worth 1,000 words and all, but it shouldn't have any play in it.
Best thing to do is have someone turn the front wheels back and forth while you lay in front of the truck and watch the connection on the drivers side.
If it moves more than a couple of millimeters, you need a new one.
Here's a couple of links to threads on it.
https://www.dieseltruckresource.com/...d=5218;start=0
https://www.dieseltruckresource.com/...d=4433;start=0
https://www.dieseltruckresource.com/...d=6279;start=0
https://www.dieseltruckresource.com/...d=8860;start=0
Good luck.
phox
Old Jan 31, 2003 | 09:05 PM
doomgaze's Avatar
The descriptions under those links sound about like my problem.<br><br>Death Wobble... wow, I have never come across something so correctly named. It was very scarey.<br><br>Thank you for the links, phox.
Old Jan 31, 2003 | 09:15 PM
figure_9_pro's Avatar
I had the same thing happen to me, check your steering stabilizer, mine was leaking oil, changed it and it hasn't happened again
Old Jan 31, 2003 | 09:30 PM
DieselDaze's Avatar
<br><br>Sounds like the &quot;Death Wobble&quot; as mentioned before. Could you have possible knocked the trackbar lose when you &quot;almost slid into a telephone pole&quot;?<br><br>Did you hit any curbs or paking blocks while in that slide that might have stressed or knocked you track bar lose?<br><br>Check the front end for lose or warn parts... especially the track bar.<br><br>Good luck and be safe.<br><br>Rich
Old Jan 31, 2003 | 09:35 PM
mic646's Avatar
The way things are going for you - DON’T LAY IN FRONT OF THE TRUCK!!!!
Old Jan 31, 2003 | 09:57 PM
doomgaze's Avatar
[quote author=T.Clark link=board=13;threadid=10352;start=0#99102 date=1044070500]<br>The way things are going for you - DON’T LAY IN FRONT OF THE TRUCK!!!!<br>[/quote]<br><br>No kidding, huh? I'm not going to inspect any further until tomorrow morning... hopefully this wonderful luck will pass by then!<br><br><br>DieselDaze, I didn't actually hit anything while in the slide (thankfully). I came to a stop about an inch in front of the pole. It was all frozen driveway right up to it, no curbs.<br><br>The first truck stop I pulled into checking for fuel was very rough though. And the interstate had some pretty harsh spots in it. So it's very realistic that this problem just manifested itself tonight.<br><br>If it is the track bar, I'm assuming that if I talk to a dealer about it, they will want to replace the entire bar and not just the pieces that Luke's Links replaces?<br>
Old Jan 31, 2003 | 10:45 PM
doomgaze's Avatar
Will driving it with a worn out track bar do any more damage than what's already done?<br><br>It seems to still drive okay at lower speeds.
Old Jan 31, 2003 | 10:59 PM
TPilaske's Avatar
[quote author=doomgaze link=board=13;threadid=10352;start=0#99071 date=1044066335]<br>Ok, nothing seemed to be noticably wrong after I stopped. I decided to tell myself it was just the interstate that was VERY bumpy in that area. (Although, I know in my heart that NO ROAD is THIS bumpy.)<br>[/quote]<br><br><br>Try Southbound I-75 in Michigan between exits 42 - 37... at least they will be tearing it up in the spring... ;D
Old Jan 31, 2003 | 11:21 PM
doomgaze's Avatar
[quote author=TPilaske link=board=13;threadid=10352;start=0#99142 date=1044075550]<br>Try Southbound I-75 in Michigan between exits 42 - 37... at least they will be tearing it up in the spring... ;D<br>[/quote]<br><br>This was Southbound I-75 between Bowling Green &amp; Findlay Ohio. Maybe it is partly the road. I-75 isn't exactly know for smoothness
Old Feb 1, 2003 | 09:50 AM
TPilaske's Avatar
<br>This was Southbound I-75 between Bowling Green &amp; Findlay Ohio. Maybe it is partly the road. I-75 isn't exactly know for smoothness <br>
<br><br><br>You got that right... you used to almost hop into the other lane in that stretch going northbound... finally re-did it all... <br>
Old Feb 3, 2003 | 01:03 AM
westcoaster's Avatar
<br>You could also have had a pile of snow packed into the inside of one (or more) rims. I have had this happen with thick mud.<br>Just guessing...
Old Feb 3, 2003 | 02:47 PM
hvanflee's Avatar
You may want to check bearing on the front axil, I had a very bad wobble on my 4X4 one day. I took apart the front hubs and found the seal, bearings and 4x4 locking hub all in a very bad way. You may also check the U joins on the drive line, if they are tight or seized, they can create quite the wobble at about 60 mph. Good luck.
