Getrag questions
Old Jan 12, 2012 | 08:25 PM
12valvewagon91's Avatar
Getrag questions
When I started rebuilding this tranny, it was smoked pretty hard. I had to replace the 3-4 slider due to galling on the fork slot. Well, I noticed there is 2 grooves on one side of the slider, and the other is smooth. I couldnt really see a difference from one side to the other, but I re installed it like it came appart. Mine had the grooves facing the rear of the tranny. Is that correct? Or does it not matter.
Also, I have the top plate set on it, have the tail housing bolted on it, nothing set up as far as preload, just checking how it bench shifts. Well all is great except 5th, seems to want to fall out of 5th without even turning the shaft, like the detent is weak. Will it feel odd if the reverse light switch is out of it?
Kasey
rbrettctd
Jul 4, 2007 11:39 PM
Terraizer
Apr 19, 2007 09:41 PM
justagoodolboy
Mar 20, 2007 07:33 PM
G1625S
May 2, 2006 08:55 AM
1stGenBikeHauler
Oct 29, 2002 11:48 PM
