Getrag Questions
I have a getrag question, My tranny shifter is pretty tight for a 280k plus truck. If you are driving down the street in 3rd gear at part throttle, you can reach up and pull it out of gear real easy. It dosen't fall out of gear, but it can be pulled out. I was just wondering if ya'll had any ideas. thanks
ez
ez
EZ, it is possible that your synchros are getting worn and not holding the gear engaged completley, but it is hard to say that with any certainty..
If it is shifting INTO gear OK, its probably not an issue
Is this while the gears are in load, float, or coast setting? If in float, it is normal. if it is in load or coast, it is likely your retaining ***** and springs in the synchro assembly are getting worn, not letting the snchro ring hold the selector in place.
Daniel
Daniel
justagoodolboy
Mar 20, 2007 07:33 PM
1stGenBikeHauler
Oct 29, 2002 11:48 PM
