Getrag questions?
Old Jul 4, 2007 | 11:50 AM
rbrettctd's Avatar
Question Getrag questions?
Can anyone have a Getrag service manual in PDF that they can pm me? Im rebuilding one, but having tough time pulling the countershaft. What is a good source for shims in the tailhousing.
Old Jul 4, 2007 | 12:22 PM
dpuckett's Avatar
On the front of the transmission, down low on the front of the case, is a rubber covered steel plug. Take a punch and punch out the middle, and then pry the plug out of it. Remove the snaprings. The counter shaft drives out the front with a long large punch and a 8# hammer. Once you remove the shaft, the cluster gear pulls right out.
You can get shims through Zumbrota Bearing and Gear and a few others. NV4500 shims will work for the main shaft, but are too big for the counter shaft. If you cant find any, PM me; I have resources.
PM JLEONARD for the getrag PDF file.
Daniel
Old Jul 4, 2007 | 09:43 PM
12valve@heart's Avatar
You have a PM.
I got my shims from Standard Transmission.
http://www.standardtransmission.com/
Old Jul 4, 2007 | 11:39 PM
rbrettctd's Avatar
Thanks everyone. Found a service manual online, and standard transmission is 30 minutes from me. For the countershaft, we got the plug out, and finally figured out to pull the shaft. Thanks again, Randy.
Stamey
Jun 1, 2008 05:55 PM
Terraizer
Apr 19, 2007 09:41 PM
justagoodolboy
Mar 20, 2007 07:33 PM
G1625S
May 2, 2006 08:55 AM
1stGenBikeHauler
Oct 29, 2002 11:48 PM
