Getrag?
Old Nov 28, 2013 | 09:17 PM
Brian.B's Avatar
Getrag?
hey guys can a 2 wheel drive getrag fit in a 4 wheel drive ,,,,
Old Nov 28, 2013 | 10:06 PM
JimmieD's Avatar
Which particular Getrag: model, type, year? There's more than one...
Old Nov 28, 2013 | 10:36 PM
maybe368's Avatar
I am not sure of the internal differences, but here is a pic of the external...Mark
Old Nov 29, 2013 | 09:35 AM
simplysmn's Avatar
You have to change the Main shaft and put the 4x4 housing on .
Old Nov 30, 2013 | 12:30 PM
u2slow's Avatar
Using a divorced transfer case is another option... wheelbase permitting of course.
Old Nov 30, 2013 | 12:46 PM
Great point, a divorced NP-205 would work for a RCLB truck, but even better on a ECLB or Crew project.
I have run one in an old '72 RCSB Power Wagon on 39s.
The rear driveshaft was really short with the divorced NP-205, and the 7 inch lift, I drove out of the woods using my front drive shaft only more than once.
Old Nov 30, 2013 | 02:19 PM
simplysmn's Avatar
You can do that but like my buddy pointed out that mean's you are adding 2 set's of u joint's and another slip joint to the mix with the Torque of the cummin's its easier to find the right transfer case . I was going to do a div case on my crewcab but choose to go with stuff that mates up .
Old Nov 30, 2013 | 03:08 PM
u2slow's Avatar
I'm just throwing out another option, as Getrags (even cores) are getting difficult/costly to acquire.
Keep in mind the jackshaft never sees the torque of low range. The longer front driveshaft runs at a nice easy angle even with a big lift.
Old Nov 30, 2013 | 03:13 PM
simplysmn's Avatar
Very true but are they just trouble anyway ? alot of you stick guy's go NV4500 in the longrun and end up better off .But yes you can do div either way will work .
Old Nov 30, 2013 | 03:39 PM
u2slow's Avatar
^ Another possible option. However, some say it doesn't shift as nice as the Getrag. IMHO, you get to the point where piece-meal dodge/cummins parts cost more than a whole donor truck. I guess that's why my yard looks like a wrecking yard
OkJeeper
Apr 24, 2003 10:32 AM
Monty
Jan 21, 2003 03:40 AM
1stGenBikeHauler
Oct 29, 2002 11:48 PM
Palmetto_kid
Oct 16, 2002 05:41 PM
