getrag 2wd 4wd differnace
Old Nov 1, 2007 | 09:45 PM
rmk4x4's Avatar
what is the differnce in them and can i convert a 2wd to a 4wd cheap dont mind tearing it down thanks
Old Nov 1, 2007 | 10:01 PM
bgilbert's Avatar
Mainshafts and tailhousings are different. Hard part or expensive part is finding getrag parts.
Old Nov 1, 2007 | 10:02 PM
PapeCAT's Avatar
mainshaft and tailshaft housings are the main differences. MAin case, counter shaft, input shaft, shifter etc are all the same yah.
Old Nov 2, 2007 | 10:22 PM
dpuckett's Avatar
Actually, depeding on the distance involved from the t-case adaptor, you might get away with just putting your sleeve on the 2wd output shaft, though that would be a long shot- matching size and spline count from 2wd to 4wd. It is feasible, in theory.
The only difference from 2wd to 4wd has already been mentioned. There is a difference regarding the reverse idler and its installation from the "old style" to the "new style". Not sure on the cutoff date, but I have had both apart.
Daniel
Old Dec 28, 2007 | 06:52 PM
feveree40's Avatar
so I couldn't bolt a 2wd getrag in place of my 4wd getrag without changing anything?
Old Dec 28, 2007 | 07:04 PM
Nope. You would need to change the output shaft and tailshaft housing.
Old Dec 28, 2007 | 07:09 PM
feveree40's Avatar
darn, I found a 2wd getrag that I was hoping I could rebuild then swap into my truck, that way I wouldn't be without wheels for as long.
Old Dec 29, 2007 | 02:29 AM
PapeCAT's Avatar
nope unless you wanted to go to a 1stgen crewcab swap or mega cab swap and have the 2wd trans in there hooked up to a divorced xfer case.
93Fury
Mar 31, 2010 01:33 PM
Jordan5687
Feb 18, 2009 02:48 PM
csramsey640
May 27, 2006 06:58 AM
1320
May 6, 2003 06:30 PM
