Should I use 4wd shocks on a 2wd??...ATTN, raised 2wd guys!
Old Feb 17, 2009 | 07:18 PM
Jordan5687's Avatar
Exclamation Should I use 4wd shocks on a 2wd??...ATTN, raised 2wd guys!
I'm about to place an order for some things for my 01 front end. I have found everything BUT the shocks for it. I'm going to be raising the front about 1.5"-2" But I have been all over the place trying to find shocks that'll work with that, but nothing for a 2wd at all. I found one pair but they're super expensive and there's got to be more than that out there. What have others done?? I was thinking just using 4wd front shocks, but I don't know if it'll work or not. What else is there?? I'm trying to place an order tonight, would appreciate the help. Thanks guys!
Old Feb 17, 2009 | 10:05 PM
SO5.9's Avatar
I have a 2" lift on the front of my 2wd. Been using the stock shocks for 50k miles now.
Old Feb 18, 2009 | 02:55 AM
R.T.D.H.S.P.'s Avatar
Pro Comp ES 9000s are what I run
Old Feb 18, 2009 | 08:11 AM
Dieselcamper's Avatar
I have a 1.5" daystar lift in the front and use stock length gas shocks
from Les Schwab $34.95 ea. been working great for 50,000+ miles
Old Feb 18, 2009 | 02:41 PM
Z06-LITE's Avatar
Same for me, just less miles.
Old Feb 18, 2009 | 02:48 PM
12valve's Avatar
bought some special REFLEX they are 2" longer, but cant find the number anymore.
on another one i customized the stock shocks, bring the upper mounting point a bit higher.
Stock shocks are too short for 2" lift, on a bad road the body will pull on the shocks on the way out, giving it a bad ride.
93Fury
Mar 31, 2010 01:33 PM
EverydayDiesel
Aug 19, 2007 09:38 AM
Bamboozal
Aug 19, 2003 03:15 PM
1320
May 6, 2003 06:30 PM
redramnc
Mar 18, 2003 03:35 PM
