air filter help...
Old Mar 7, 2007 | 11:36 AM
93beater's Avatar
Question air filter help...
ok can i run a bhaf with the stock intake, or do i have to custom make an intake, or is it just as good to slap a k&n in there and call it done?
Old Mar 7, 2007 | 11:48 AM
Chrisreyn's Avatar
Alot of guys have commented on finding gunk on teh turbo impeller after running the K&N, so I wouldnt recommend it...
the outlet on teh BHAF filter is 4", same as the intake. I just slipped the BHAF into the intake and clamped it, has worked for me so far, but a few others recommend a short piece of 4" tubing to reinforce it and prevent the hose from sliding off.
Old Mar 7, 2007 | 11:54 AM
93beater's Avatar
ok well i think ill buy the filter, keep the stock box, and make an aftermarket tube from the turbo, it seems and looks super simple, thans for the help!!
Old Mar 7, 2007 | 11:56 AM
Chrisreyn's Avatar
if you search "intake" you will get threads tellign how to build an good intake tube assymbly. The BHAF wont fit in the stock box, so you will have to fab a mount of some sort. Look in teh "stickey" for the "Old Smokey Mount" its pretty simple and took me less than an hour to fab up in my garage.
https://www.dieseltruckresource.com/...d.php?t=102027
Old Mar 7, 2007 | 11:59 AM
93beater's Avatar
ok sounds liek a plan, thanks!
Old Mar 7, 2007 | 02:07 PM
rlyons's Avatar
Here is the ASA Modifieds I run, it works great and sounds better.
Old Mar 7, 2007 | 04:30 PM
The stock intake hose has an annoying habit of falling off the BHAF - that's why I switched to the "airflo" intake setup.
Old Mar 7, 2007 | 06:14 PM
timb's Avatar
I likey the looks of that.
Old Mar 7, 2007 | 06:24 PM
93beater's Avatar
ok well can anyone tell me where to buy all the materials including the filter, and about how much it will run me? thanks
Old Mar 7, 2007 | 07:22 PM
rlyons's Avatar
Peirs is now the retailer for ASA Modifieds.
PDR3510004 1st Gen Dodge Air Intake System w/ aFe filter available in Silver, Black or Red $189.00
http://www.piersdiesel.com/DodgeUSPrice.htm
Old Mar 7, 2007 | 07:43 PM
DODGE 92's Avatar
air filter
i got k/n works just fine
Old Mar 7, 2007 | 07:44 PM
G1625S's Avatar
4'' 45 rubber elbow---12.50 a pieceX2
1' intake tubing---7.40
t-bolt clamps---5.11X4
all the above can be found at www.airflo.com
BHAF---37.43 www.fleetfilter.com
Old Mar 7, 2007 | 11:27 PM
Ace's Avatar
Ace
I like my K&N. Give it a quick shot of oil couple times a year, put it back in and fuggedaboudit. Never found anything unusual in the turbo intake area, dirt, grime, near white-glove clean both times I checked it so far. Don't plan on cleaning it any time soon. Best part was it came with the truck!
Old Mar 7, 2007 | 11:37 PM
1stGen545's Avatar
Mine came with a K&N but AFE makes one that I like better. Just don't over oil them. The BHAF will work fine lots of guys run them and like them. I just like having a cleanable filter that I only have to by once. I have heard that the BHAF lasts a good while.
Old Mar 8, 2007 | 11:40 AM
93beater's Avatar
i have decided on buying the bhaf and making my own intake with the materials ^ he said to use. it should be easy and cheap, ill keep ya'll in touch.
