Getrag
Old Jun 8, 2008 | 12:51 AM
w250_93's Avatar
Getrag
I took it apart today found that the counter shaft bearings were bad and that the 1st-2nd syncro ring was cracked (not the brass part but the ring that the brass ring sets in) that explains why i couldn't get it to go into 1st without it grinding, and i think somebody has has this thing apart before because it has koyo japanese bearings in it, also i found out that i have a luk clutch but it still don't hold the power.
Old Jun 8, 2008 | 12:58 AM
Alwaysworking's Avatar
alwaysonDTR
do you have the book?
when the clutchs get old the pressure plate wont hold the power anymore.
Old Jun 8, 2008 | 06:13 AM
G1625S's Avatar
Lots of folks running with Koyo's with good luck, but to each his own. Luk clutch= Measure the disk. It's likely 12.25''. Throw it out and replace it with an original Sachs unit or a 13'' South Bend unit before you put that tranny back in.
Old Jun 8, 2008 | 09:05 AM
avewilson's Avatar
My uncle is a powertrain engineer at american axle, and he told me when I was doing my getrag that Koyo makes the best bearings in the world.
Old Jun 8, 2008 | 10:02 AM
MoparMarv's Avatar
Koyos were in mine when I took it apart a few months ago. I would bet they were stock from the factory. And I believe they are a good brand. Parr with timken I would say.
Old Jun 8, 2008 | 10:45 AM
bgilbert's Avatar
Koyo's are the only bearing you can get for the Getrag. I've found I can all of the getrag bearings locally for about the same price as a kit plus shipping from www.zbag.com. In the kit you get front and rear oil seals, front 'freeze' plug, pto and top cover gaskets. I suggest buying a bearing and synchro kit and shims from zbag. They also have good used and new parts. That 1/2 synchro assembly is not cheap, about $300 used or new.
Old Jun 8, 2008 | 03:01 PM
Mine has F A G bearings in it, I got them a couple years ago. They are German, good quality stuff.
Old Jun 8, 2008 | 05:48 PM
w250_93's Avatar
what do you guys think of maybe tig welding the syncro assembly back together, i don't have the book but i have acess to the mitchel ondemand 5 program on the internet but i still wouldn't mind having the book.
Old Jun 8, 2008 | 05:54 PM
12valve@heart's Avatar
PM me your e-mail address and I'll send you the .pdf of the Getrag part of the FSM. It's what I used to rebuild mine.
Old Jun 9, 2008 | 01:13 AM
alwaysonDTR
or you can pm me your e-mail and i'll send it to you
Old Jun 9, 2008 | 04:58 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
Don't mean to hijack but what does everyone recomend for getrag lube brand and weight
Old Jun 9, 2008 | 05:50 PM
w250_93's Avatar
5w-30 engine oil
OkJeeper
Apr 24, 2003 10:32 AM
Monty
Jan 21, 2003 03:40 AM
1stGenBikeHauler
Oct 29, 2002 11:48 PM
Palmetto_kid
Oct 16, 2002 05:41 PM
