Get Rag still grinds!!! ahhhh!! help!
Old Mar 26, 2012 | 12:04 AM
dszoo's Avatar
So I just finnished rebuilding my Getrag, all new brass syncros, new 3rd gear, new 3&4 syncor ring, new imput shaft, new south bend clutch, new roller bering pilot bering, all new bearing in the tranny ect...... took the girl for a test drive, and she still grinds, some times in to 3rd when down shifting. Is it me? am I down shifting too fast?.... do the new and old marts just need a chance to mesh together?... I dont want to take the rag out again if I dont have to..... she is a heavy pig! lol any help any one can offer would be great!!!
Old Mar 26, 2012 | 06:30 AM
Glen_63's Avatar
Is the the clutch releasing fully? How sloppy is your clutch pedal?
Old Mar 26, 2012 | 10:10 AM
SORTIE's Avatar
I cleared up a bunch of grinding by replacing the master cylinder and slave cylinder (and being more deliberate with my shifting)
Old Mar 26, 2012 | 11:20 AM
brainfade's Avatar
Mine seems to be happiest with a little speed matching on down shifts (4th to 3rd for example). I depress the clutch, put the shifter in neutral, release the clutch and blip the throttle to bring the RPMs up, push down the clutch and it goes right in like butter. It sounds more difficult than it is, a little practice is all it takes. Keep in mind that the rotating parts in the trans are heavy and it takes the syncros a little time to match things up.
Old Mar 26, 2012 | 08:10 PM
dszoo's Avatar
Thanks for the replys, I should menton that i did over fill the rag like everyone says to do. the clutch peddle seems ok... is there a way to test before i drop the cash on new hydros. ?
Old Mar 26, 2012 | 10:51 PM
Glen_63's Avatar
Is it level with the other pedals? Check the rod end and rod for wear you should be able to see and feel it where the 2 connect if you have any.
Old Mar 28, 2012 | 12:04 PM
big stinky's Avatar
What fluid in the tranny?
Old Mar 29, 2012 | 12:29 PM
Rotten's Avatar
I'm with Brainfade, I shift mine like its got an eaton fuller 10 speed, and match revs, double clutch, and it goes into gear with only 2 fingers worth of effort.
Old Apr 3, 2012 | 12:28 AM
dszoo's Avatar
i have mobile 1 530 full syn, i am going to have a look at the hydros this weekend, thanks for the ideas guys!
Old Apr 3, 2012 | 12:57 AM
pulltilbroke's Avatar
Best Paint (Getrag category)
I would pull the tranny and get the junk roller bearing out of there and replace it with a good ball bearing like what Southbend and Valair uses in there clutches. Machine work is required on the stock flywheel.
Old Apr 3, 2012 | 09:04 AM
dszoo's Avatar
I put a SB clutch in at time of rebuild, and I did updatet the pilot dearing.
Old Apr 3, 2012 | 09:30 AM
I had the exact same issue with my Toyota pickup 5 speed.
Turns out that I was using Amsoil 75-140 GL-5 Gear oil. Turns out the weight was correct, but the GL rating was not.
Toyota requires a GL-4 Rated oil in their manual transmissions, as they require "less slppage" between the gears. When I finally switched over to the GL-4 the difference was amazing.
ted_pulliam
24
Apr 10, 2012 01:30 PM
mt250
Dec 4, 2011 12:01 PM
my dodge sucks
May 19, 2011 12:17 PM
BMH95
Jul 30, 2008 08:33 AM
kentuckydiesel
Mar 12, 2007 09:12 PM
