Gear Box
Old May 19, 2009 | 09:07 PM
12vkaleb's Avatar
Gear Box
I was under the truck the other day checking everthing out do to abunch of slop and pops in the front end and there was a bolt missing out of the gear box where it bolts to the frame. Anybody else had this happened to them?
Old May 20, 2009 | 09:02 AM
wheelo90's Avatar
yeah this has happened to me, ended up busting and ear off of the gear box itself where the bolts go through. had to get a new one out of a junk yard. also check the mounting plate, they are very well known for cracking. To prevent this from happening, i use a torque wrench, and some loctite to keep the from coming loose and causing a cracked box or plate.
I also had a lot of play in my drag link, cheap $95 fix, steers like a champ now though. Check tie rod ends as well.
Old May 20, 2009 | 10:30 AM
12vkaleb's Avatar
Oh i know everything was loose under there. Do i have to take the plate off the frame to get those bolts back in? I didnt see any other way around it. Do you have any other suggestions? Thanks
04ctd
Oct 5, 2006 08:27 PM
JohnInNH
15
Sep 3, 2006 08:22 AM
mhuppertz
Aug 19, 2006 09:17 AM
trout74
Aug 29, 2005 06:25 PM
Hummin Cummins
Dec 25, 2002 12:29 AM
