Gauge wiring help
On my Autometer gauges, the boost only needed wiring for the light bulb. The egt gauge had wiring for the gauge and for the light bulb. I just got some fuse taps from carquest and tapped a fuse that had key-on key-off power to power the egt gauge. (use a tester to find out which fuses do what if you need to) Then I found a fuse that was powered with the head lights and used a fuse tap to hook up power to the bulbs on both gauges. All that's left is to tie the grounds to a screw on the body. If the gauges don't come with enough wire to reach where you need them to, you will have to buy some light gauge wire and some spade connectors. You also need spade connectors to attach to your fuse taps.
610dodge
Aug 19, 2006 04:35 PM
Phil n Az
Jul 17, 2006 08:19 AM
Graphite600
Aug 20, 2005 08:50 AM
PHX_ATC
May 19, 2004 03:13 PM
