Help On Gauge Wiring!
Old Aug 19, 2005 | 11:37 AM
Graphite600's Avatar
Quick question on wiring gauge lights, can I connect them all together or do I have to run seperate wires for each gauge light? If I can connect them together what method of securing the wires together should I use (18 awg wire nuts)?????
Old Aug 19, 2005 | 12:18 PM
Mike D's Avatar
Yes, you can connect all the wire together all reds and all blacks, I would recommend soldering. Then run one wire to a keyed fuse and the other to a good ground.
Old Aug 19, 2005 | 12:34 PM
Cant I just find a wire in the headlight switch and hook it to that, and a good ground somewhere?
Old Aug 19, 2005 | 02:29 PM
Mike D's Avatar
Yes.
Old Aug 20, 2005 | 08:50 AM
nickleinonen's Avatar
good ground can be had under the dash drivers side knee panel. the steel cross tube there is a pretty good ground.
you can download some wiring diagrams here
on that 05 schematic, on page 8W-40-5, pin E2 color orange with brown tracer should be the dimmer wire for lighting. there is another same color orange with brown tracer wire that is E19 that looks to be the ground side of the lighting circuit
TNLoneWolf
Apr 5, 2008 10:46 AM
610dodge
Aug 19, 2006 04:35 PM
Phil n Az
Jul 17, 2006 08:19 AM
Evildiesel
Jul 2, 2006 06:39 PM
PHX_ATC
May 19, 2004 03:13 PM
