Gauge Installation Questions
Just a couple questions on what you all did with some of the
hook-ups?
I was considering tapping the 1/8'' pipe thread for the boost-gauge into the aluminum flanged 90 atop the intake manifold, will this be to hot for the autometer plastic tubeing?? has anyone did theirs this way?
Where should i install the trans temp sender? Is their a pipe plug or do I
need to tie into the tubeing fittings?
How did most of you guys wire for gauge lights?
I can probably find 12v off the lite switch, but i think i would prefer to
connect to the dimmer, just don't know what color wire to attach to.
New truck, i need to update my info.
92 std. cab 4x4, a518, 16cm, autometer gauges
hook-ups?
Greg
I can tell you the tubing is totally fine, no issue there.
Trans temp shoudl be in the hot line going out to the cooler, it can be done with fittings (cutting the line) or I belive they sell a replacement line with a welded bung (not sure about the earlier trucks)
It's pretty easy to get a test light and probe around behind you headlight switch to find the dimmer. On the 2nd gen trucks it is brown/orange, not sure on yours.
Someone who knows more will chime in.
Thanks for all the help, just finished the job.
I Metered the gauge lighting circuit @ the fuse block and found it to be dimming as darkvader suggested. (thanks)
I also found a 3/8'' pipe bung inline attached
to one of the ATF cooling lines, their was a factory switch/sensor already installed there, so I put in a 3/8'' tee and installed my tranny temp sensor.
(I hope I got the right tubeing)
The 1/8'' boost port on the manifold, another great tip, Thanks again for all the help!
Bryan
Bryan
Originally Posted by whereswaldo250
gman07,
how accurate is you boost guage where you attached it and what is really supposed to go there.
thatks
thatks
The dash lights run over to both the radio and heater controls. That's where I hooked my gauge lights. I got the 12V accessory line at the radio also for the tach and pyro.
See my gallery for the dashtop mounting.
Edwin
Where did you get your waste gate at? and is it worth getting for a stock turbo?
Thanks
Thanks
It made all the difference in my truck. I also got a boost controller to be able to add some boost above the factory setting. It works by delaying the boost pressure to the wastegate actuator. Now it make me grin until my face hurts.
Edwin
Originally Posted by gman07
As far as the boost gauge goes, there is a plug you can take out and get the boost there - it's already tapped and everything. Here's a picture of it:
Bryan
Bryan
That's where the wastegate is supposed to hook up so that is the proper place for the boost gauge. I ran a 3/16 rubber line from a brass hose barb I put in the boost port then T'd it for the boost and wastegate.
is the plug (and thus the replacement barb) a 1/8 NPT fitting? i.e. my EGT probe would've threaded into the same hole? no...I'm not installing it there, just making sure I buy the right part...
Greg
Greg
Greg
dgibbs
Dec 22, 2005 09:19 PM
blderman
Apr 30, 2005 07:08 AM
NWDave
18
Dec 30, 2002 07:56 PM
