g 360 no 3rd or 4th manual tran.. any answers?
It's broke.
Probably a worn out 3-4 shift fork. The trans will have to be removed unless you want to cut a big hole in the trans tunnel so you can get the top cover off.
http://www.standardtransmission.com/
These guys can get you the parts to fix it.
Hey Smokesplitter,
I whacked mine open with the cut-off tool...then I made a new (bigger) cover to go over the opening.
Use a body hammer or ball-peen (round end) to form it to the trans hump and hammer a couple ridges in it for stiffening.
Now I can access the shifter case any old time...and that's where you'll find the shift forks.
As long as there's no build-up of aluminum where the fork sits you should just be able to replace the shift fork,although the trans section of the FSM has no instructions on how to do it.
It just says to replace it as a unit.
I had a problem with mine jamming in gear...I put a rebuilt shifter case on and been slappin' gears ever since. The rebuilt case cost me $200 (no core) from a place out here in IL...well worth it to me.
Vinny
Vinny
You can get the forks from blumenthal's in OKC Oklahoma( http://www.blumenthalmfg.com/ ph #(888) 236-4800
), Thats where i got em from, dont have to buy whole cover
I got a fork for 3rd and 4th gear for $40. Replaced it and works fine. It was caused by excessive play in tranny where the gears come apart to remove. A few new bearings and no play in the shaft and all my gears back.
Originally posted by C Pierce
Jim's right it took me and 1 helper about 5 hours total to pull fix and reinstall my GT360 and we was draggin our feet!
buckman361
10-10-2008 11:23 PM
LaneFarms
05-13-2006 04:40 PM
