-   1st Gen. Ram - All Topics (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/)
-   -   g 360 no 3rd or 4th manual tran.. any answers? (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/g-360-no-3rd-4th-manual-tran-any-answers-63580/)
smokespitter 03-13-2005 07:43 PM
no 3rd or 4th . manual trans. ??????????
wannadiesel 03-13-2005 07:55 PM
It's broke. ;)
Probably a worn out 3-4 shift fork. The trans will have to be removed unless you want to cut a big hole in the trans tunnel so you can get the top cover off.
http://www.standardtransmission.com/
These guys can get you the parts to fix it.
smokespitter 03-13-2005 08:08 PM
the trans tunnel doenst un-
bolt??????
torquefan 03-13-2005 08:14 PM
bolt??????
Nope.
smokespitter 03-13-2005 08:16 PM
get the tourches out!!!!!
vinny 03-14-2005 04:07 AM
Hey Smokesplitter,
I whacked mine open with the cut-off tool...then I made a new (bigger) cover to go over the opening.
Use a body hammer or ball-peen (round end) to form it to the trans hump and hammer a couple ridges in it for stiffening.
Now I can access the shifter case any old time...and that's where you'll find the shift forks.
As long as there's no build-up of aluminum where the fork sits you should just be able to replace the shift fork,although the trans section of the FSM has no instructions on how to do it.
It just says to replace it as a unit.
I had a problem with mine jamming in gear...I put a rebuilt shifter case on and been slappin' gears ever since. The rebuilt case cost me $200 (no core) from a place out here in IL...well worth it to me.
Vinny
Jim Shulmister 03-14-2005 06:18 AM
A 2wd tranny comes out in 45 mins, just rip it out and put it on the bench.
-Jim-
C Pierce 03-14-2005 07:52 PM
Jim's right it took me and 1 helper about 5 hours total to pull fix and reinstall my GT360 and we was draggin our feet!
th_racer 03-14-2005 08:32 PM
You can get the forks from blumenthal's in OKC Oklahoma( http://www.blumenthalmfg.com/ ph #(888) 236-4800
), Thats where i got em from, dont have to buy whole cover:D
Den 03-14-2005 08:46 PM
Smokespitter,
Fill in your profile and location and maybe you can find somebody local to volunteer to give you a hand.
Den
1st gen Hobie 03-24-2005 12:23 PM
I got a fork for 3rd and 4th gear for $40. Replaced it and works fine. It was caused by excessive play in tranny where the gears come apart to remove. A few new bearings and no play in the shaft and all my gears back.
edwinsmith 03-24-2005 01:00 PM
For me that would be a six-pack and a half. :D
