Fuel screw max'ed from the factory?
Old Mar 25, 2020 | 07:52 PM
I am doing some work on my '93 12V motor for my 2wd to 4x4 club cab build.
I pulled the tamper proof screw cap off the virgin, original VE pumps fuel screw on the motor today. The collar was bottomed right out against the jam nut on the fuel screw.
So, I backed the screw out and carefully removed the collar. I then got the jamb nut to back up the threads smoothly with some pick work and time.
I thought I would install the fuel screw back in less than a turn more than stock and save the real pump turning for once it was in the truck.
I got it back in and tightened down to the stock location again no problem.
I felt light resistance trying to get the extra turn, I would say less than 1/8 of a turn extra and felt it. I stoped there and have been researching if anyone else has had this issue.
I haven't found much in the sticky and such, but know each pump is different. Maybe I am at full fuel screw adjustment in stock form on this auto '93 pump?
Before I removed it, the collar was at the very end of the fuel screw and there where no screw threads exposed behind it.
Any thoughts DTR'ers?
Old Mar 25, 2020 | 08:36 PM
AZ2A's Avatar
my 93 w250 with getrag was same way, I couldn't get even 1/8 turn on it..trucks no slouch so...
Old Mar 26, 2020 | 04:02 PM
u2slow's Avatar
Compounded manufacturing tolerances are probably the reason. When a fuel shop tunes a pump, they twist the screws until it delivers whatever volume and pressure is spec'ed. Where the screw thread lands is not important.
I believe there's more screw adjustment on a non-IC pump... to the point you can adjust it to runaway. This is probably one of the reasons there's less thread/adjustment on the IC pumps.
dkimmel
Jan 16, 2011 08:24 PM
The_Head
Apr 30, 2009 10:47 PM
77machomopar
Dec 31, 2008 07:59 PM
IRoss
Feb 5, 2008 08:27 PM
Dean Snow
Oct 22, 2007 07:26 PM
