Resistance in Fuel Screw
The other day while messin with the IP I had a helluvatime backing off the fuel screw...it literally felt stuck, as if something was holding enough pressure on the inside end to prevent it from turning...once I managed to back it off a quarter turn it spun fine, so I backed it out a bit more to look at the threads, and they looked fine, but now I can not turn it any more past that last setting, there is a definite stopping point there somewhere...
I dont remember hitting any such resistance the last time I turned the screw in....there is about 1/2" of screw left sticking out the back of the pump....is this normal for the screw to bottom out like this without runaway?
ryan10-looking at the pics in the sticky on extending the fuel screw makes things a little clearer....there is an o-ring in the middle of the screw, inside the pump, which causes the resistance, I would think forcing the screw in would result in a smushed o-ring, which would probably result in a leak of some sort....am I correct here guys?, does the o-ring slide forward in a bore in the pump housing and then eventually bottom out?
jmd4993
Jun 22, 2013 07:36 AM
littlebuddie
Feb 17, 2009 06:30 PM
HOHN
Oct 18, 2004 11:48 PM
