fuel pump rebuild advice
Old Jun 24, 2004 | 05:56 PM
adamroofer25's Avatar
I just dropped my pump off at the pump shop for a rebuild and I was wondering if there is anything in particular that I need to do before start up after I install the new pump. The pump is going to be stock except for a 3200 gov. spring. I would rather do the rest of the adjustments myself after installation. I would also like to say how thankful I am for all of your help. This website has saved me tremendous amounts of time and money. Thanks for all the help.
Old Jun 25, 2004 | 01:07 PM
apache's Avatar
Most shops will void the warranty if you start to turn settings after they install it. have them set it up with the 3200 gov and I think they set them to 96ccs from 88ccs or so. From what I hea most certified Cummins dealers wont alter from D/C settings but others will.
Old Jun 27, 2004 | 08:54 PM
bump
Old Jun 28, 2004 | 12:20 AM
Bushy's Avatar
Patron Saint of 1st gens
You might ask them to pin the pump at 1.7mm lift.
That will give you a good, accurate internal timing set and it's right exactly were you want it to be. That is important if you're going to tweak it later and use uprated injectors in it.
Have them set the supply side pump to it's max rated level as well. I think the setting is 3.4 ( 3.4 WHAT? I can't recall) either way the spec for the pump will have a spec "band" which is acceptable for the supply side. Have them set it to it's max allowable in that "banding".
This will improve the pressure in the high pressure head and should help with atomization a bit as well.
pb.
Old Jun 28, 2004 | 05:38 AM
Thanks Bushy, I appreciate the info. I'll call them this morning.
csa
Apr 2, 2011 09:14 AM
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
54larry
Jun 5, 2007 12:32 PM
hoehand
19
Apr 25, 2007 10:19 PM
