Decided to keep it. Need rebuild advice
Old Apr 24, 2007 | 08:52 PM
hoehand's Avatar
Well, after losing four injectors and scoring number six cylinder, I was ready to get a gasser. But, I just can't do it. I have decided to fix the dodge. I need to know about replacing a piston. Can I replace one without rebalancing? Piston sources and selections? What to do to the head while it is off? I have access to cheap labor, but I still want to keep the cost down to a reasonable level.
Thanks
Old Apr 24, 2007 | 09:45 PM
wreedCTD's Avatar
what did you do to blow up the ol cummins?
Old Apr 24, 2007 | 09:51 PM
dakotar's Avatar
really, did you starve it of oil, and four injectors?! ****
Old Apr 24, 2007 | 10:29 PM
reidsram's Avatar
that sucks man i have the same year and i need to replace 4 injectors as well. i am also scared that i mess up a cylinder as well. what were the symptoms???
Old Apr 24, 2007 | 10:50 PM
hoehand's Avatar
I lost one injector right after the other. All of them in a about a month. The first two cracked and filled the crankcase with diesel and the last two stuck shut. I only drove about 15 iles on the first one, and I guess that was all she could take. My opinion, and the opinion of most of the people I have talked to is that I just got some bad fuel.
The symptoms that the scored cylinder present is excessive oil usage and a compression issue.
Old Apr 24, 2007 | 11:51 PM
acook's Avatar
Did you have your quad/VA 3.2 when the injectors craped out?
Old Apr 25, 2007 | 05:48 AM
hoehand's Avatar
I've had them for fifty thousand hard miles. I'm sure they expedited the process, but they weren't the primary culprit. I was ready for one to crack, but four all at once lead me to believe it was fuel.
Old Apr 25, 2007 | 11:06 AM
hoehand's Avatar
Anyone have any advice?
Old Apr 25, 2007 | 11:10 AM
dodgezilla04's Avatar
order the parts from cummins. just tell them you have a 600 in a dodge. they will be the best source to get the correct stuff.
Old Apr 25, 2007 | 11:19 AM
hoehand's Avatar
I would really like to get coated pistons. Are they available through Cummins? Can I replace one piston without balancing the internal assembly? Can I do something about the valve seats while the head is off?
Does anyone know the price on the pistons?
Old Apr 25, 2007 | 11:25 AM
i bought pistons last month from cummins for a 2002 b series at $161 each.
you can replace 1 piston.
any competent machine shop can check/machine the seats if needed
Old Apr 25, 2007 | 11:32 AM
BothellDiesel's Avatar
How does bad compression show itself and how do they test for that?
Old Apr 25, 2007 | 11:35 AM
hoehand's Avatar
I had the dodge dealer run a shut down test to show which injector was bad this last time, and the mechanic told my dad that there was a compression issue in number six. I wasn't there, so that is all I know.
Old Apr 25, 2007 | 11:38 AM
Basically the diesel in oil caused the piston failure. Just curious my #1 cylinder is acting weird on a contribution tests
Old Apr 25, 2007 | 11:42 AM
hoehand's Avatar
Yeah, that is what looks like. I will know more once I get the head off. I am confident that the piston is good, but the wall i scored allowing blowby and compression loss.
