fuel pressure guage
fuel pressure guage
hey guys, how would i put a fuel pressure guage in my fuel system? and before the lift pump correct? what do i need for fittings? i already have 3/8s fuel line
Geno's garage has a tapped banjo bolt that is for a 24v I think but it will fit our trucks too. Get that and replace the banjo bolt that has the bleeder screw in it with the tapped bolt and hook the gauge up there. Jonathan is right the pressure reading so be taken after the fuel filter and before the ip.
Unless it's untaxed, then it's red.
do the first gens need the "snubber" they say is needed for the pressure spikes during start up on the 98-02 trucks?
Restrictor fitting 3279
and i want the:
"BANJO BOLT - TAPPED ('98.5-'09, 5.9L & 6.7L" 12L14 steel Banjo Fittings feature a large diameter (.187” vs. .130”) fuel port. The fittings are SAE (3/4” hex) vs. the stock 17mm hex design.
and i want the:
yep get the banjo bolt from genos so you don't have to drill and tap the one you got (bad idea!!! I tried and didn't work too good). Yes if you have a mechanical lift pump than get a snubber, otherwise your gauge will bounce everywhere and it will kill your sensor if its an electronic gauge. I just bought the autometer snubber from genos while I was ordering the banjo bolt, but you could make your own too.
snubber:
http://www.xtremediesel.com/autometer.aspx
whats this dodadd do? i imagine it just has a tiny tiny hole so too much volume cant go thru?
richie how do you have yours "wide open"?
mytrucksaslug
12-16-2007 01:11 PM
jgiachino
16
07-11-2007 07:33 PM
bigragu
01-24-2006 11:16 AM
Dodgezilla
15
03-11-2003 07:49 AM
