fuel pressure
Old Nov 21, 2010 | 08:28 PM
Exekiel69's Avatar
fuel pressure
I'm trying to get a good spot to connect the line I'll use for a fuel pressure gauge, is there a good spot I could use? I want to put it after the filter and before the IP inlet so I'll know if the filter is getting clogged. On My ford truck I didn't use the cummins filter head so it was easy to cut the inlet line to the IP and put a T there, on this other engine I will keep the cummins filter head so I'd like to know if there is a way to accomplish this with out cutting the line.
Thank You.
Old Nov 21, 2010 | 08:44 PM
Onemoparnut's Avatar
Get a tapped banjo bolt to replace the banjo bolt that has the bleeder screw in it. That is how a lot of people have done it.
Old Nov 22, 2010 | 11:18 AM
blackfordd's Avatar
Don't forget a "snubber" or a "needle valve" or that puppy will jump around on you until the sender finally takes a dive.
Old Nov 22, 2010 | 01:05 PM
92smokin blacky's Avatar
yesss get a snubber cuz i've had my electronic one for only a few months and the sensor already took a dump.
Old Nov 22, 2010 | 04:24 PM
Exekiel69's Avatar
Yes, the one on My other truck is already jumping like crazy, I got a valve I plan to use on it and this one as well. What do You guys refer to as snubber?
Can't I just drill the banjo bolt and tap it.
Thank You.
Old Nov 22, 2010 | 10:34 PM
I suggest getting the banjo bolt from genos. I drilled my stock one bigger and tapped it and also broke a tap while doing it... wow that whole thing was just a big mistake so i say just buy the one thats already to go and save a lot of hassle.
Old Nov 23, 2010 | 08:17 AM
Exekiel69's Avatar
Thank You.
Old Nov 23, 2010 | 05:18 PM
Exekiel69's Avatar
Where can I get this? They have one at the local hardware store but it comes with a rubber seal and I'm not sure it can take the diesel fuel.
Old Nov 23, 2010 | 06:39 PM
blackfordd's Avatar
I think Vulcan has the needle valve.
Old Nov 24, 2010 | 08:17 AM
Exekiel69's Avatar
I found this one and this one Item R7798. Are this the same thing? Doesn't look like they are but do they accomplish the same purpose?
Thank You.
Old Nov 24, 2010 | 05:29 PM
Exekiel69's Avatar
Anyone?
Old Nov 24, 2010 | 06:27 PM
blackfordd's Avatar
I have the R7798 from Diesel Manor.
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
