Fuel Pressure
Old Apr 21, 2007 | 10:02 PM
BearKiller's Avatar
Post Fuel Pressure
I got my fuel-pressure gauge plumbed in, between the filter and injection-pump.
I didn't replace the filter, as it hadn't been on there very long.
I installed the Glacier Big Line Kit, with a TEE tap for the gauge line.
On this TEE, I installed a BALL-VALVE, and a SNUBBER, then the gauge line.
When first installed, the gauge was holding 4 PSI.
With the engine idling, I shut off the BALL-VALVE, then shut down the engine and left it be for several hours.
Then, when I checked the gauge, it was still holding 4 PSI, signifying that there are no leaks in the gauge/line.
I opened the BALL-VALVE and the gauge immediately dropped to zero.
On a three hundred mile trip, the gauge stayed steady at 4 PSI, up hill and down, idle or full throttle; occassionally I saw it creep to 5 PSI, but really wasn't doing anything different.
The original 1989 diaphragm-type mechanical fuel-pump is still on the engine.
How do my observations compare with others' experience??
Thanks.
Old Apr 21, 2007 | 10:50 PM
Sounds like you have an acceptable lift pump. A real healthy diaphragm pump will do 7-8 psi, but there's nothing wrong with being able to hold 4 psi under all conditions.
The system does not hold pressure when the engine is off, this is normal.
Old Apr 22, 2007 | 08:36 AM
Ace's Avatar
Ace
That pretty much exactly how my diaphragm pump behaved.
Old Apr 23, 2007 | 07:46 AM
BearKiller's Avatar
I assume that, since the VE can draw it's own fuel, to an extent, should the lift-pump be completely dead, a pressure/vacuum gauge would show a vacuum, correct??
Old Apr 23, 2007 | 09:11 AM
Short Box's Avatar
If a diaphram pump does 7-8 psi and a piston lift pump does 4 psi, what is the advantage to a piston pump? Just wondering cause the truck I just bought seems wet around the lift pump.
Old Apr 23, 2007 | 09:34 AM
Ace's Avatar
Ace
Piston pump is rated for 15psi. The 4psi referred to above would be for the diaphragm pump.
Old Apr 23, 2007 | 04:05 PM
In the case of a dead pump, yes.
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
