Fuel line extension...
Old Dec 28, 2013 | 01:05 AM
Wondering what the crewcab guys have done to extend the fuel lines? Or did you just replace them? If so what connectors did you use, and what kind of line?
I've been trying to figure out the best way to extend, or alter the fuel lines so that they will work on my long box crewcab chassis.
Thoughts, suggestions?
Old Dec 28, 2013 | 06:52 AM
JimmieD's Avatar
One suggestion I have for guys doing diesel swaps, where you often have to change fuel lines, is to add about a foot 12" of clear vinyl tubing just before fuel filter. It makes for an easy way to diagnose air bubbles, water, grunge and contamination etc.
I just used common hardware store 'vinyl tubing', nothing special, installed with some good clamps. Held up for about 6-7 years so far, no problems.
Old Dec 28, 2013 | 09:24 AM
MARF75's Avatar
We just did some patching on my dads 93 and he found some stuff at our local carquest, its plastic just like the stock stuff. It has fittings that work with the factory "snap lock" stuff. They are barbed and push into the plastic line then you put a one time use, crimp on hose clamp on and your done. Pretty slick stuff to work with. They also make kits for adapting to steel line.
Old Dec 28, 2013 | 10:15 AM
cougar's Avatar
I would go with a larger steel line between the tank and engine with hose at the ends. Something like 3/8" should do, unless your pushing the HP way up. Because of the distance, I'd even opt for an electric pump back by the tank.
Old Dec 28, 2013 | 11:03 AM
Any chance you have a part number...or brand name?
Old Dec 28, 2013 | 11:04 AM
This is kind of the direction I was leaning towards. 3/8 line from the tank to the lift pump. Then 5/16 for the return line.
Old Dec 28, 2013 | 11:06 AM
That's good advice as well. I run a cheap clear plastic filter before the lift pump....Recommend by Bearkiller....nice to be able to see the crud coming out of the tank. But some clear line would be good too.
Old Dec 28, 2013 | 11:45 AM
simplysmn's Avatar
I just took 2 feet of rubber hose and clamped it onto the plastic no leak's and it work's fine .
Old Dec 28, 2013 | 02:10 PM
Thanks for the advice!
Guess I could always just cut and paste in a small section of metal line.
Old Dec 28, 2013 | 06:17 PM
bryson711's Avatar
I put all new line from the tank to the lift pump. I got diesel rated hose from a local diesel shop. I ran a 1/2'' line for the feed and 5/16'' for the return. I also installed a vulcan draw straw while I was doing it.
Sent from my DROID4 using Tapatalk 2
Old Dec 28, 2013 | 09:26 PM
What is this?
Old Dec 29, 2013 | 07:05 AM
It is a filler line/pick up you drill a hole for in the top of your tank.
It is about 1 inch tube for the pick up.
You keep your old fuel sending unit, as it will still read your fuel level in the tank.
The 2nd and 3rd gen crowd use them when installing FASS or Air dog style fuel pumps usually.
Old Dec 29, 2013 | 07:27 AM
bryson711's Avatar
Yep,
http://www.genosgarage.com/VULCAN-PE...fo/VULCAN_DS1/
I used this one and it worked fine. I was having issues with sucking air at half a tank because of a hole in my factory draw straw. This fixed the problem. Also too because it makes for a bigger outlet. I intend to put a p pump motor in mine in the next couple years and wanted to prep for it.
Scrambler250
Apr 9, 2005 09:28 AM
doodah
15
Feb 26, 2005 10:05 PM
Mike_Boutet
Oct 2, 2004 02:19 AM
nailzsn
Sep 29, 2003 08:00 PM
john360
Sep 25, 2003 08:47 AM
