Fuel issues, at wits end, going to crush truck.
Old Sep 11, 2016 | 04:31 PM
jimbo486's Avatar
Originally Posted by ofelas
J - sending my kid's glitter painted Giles decals your way.
Old Sep 11, 2016 | 04:51 PM
j.fonder's Avatar
I dimly recall Greg telling you to check for a sheared key a few days back...
Greg drives a Ferd, clearly knows nothing about Cummings.
And lary, I'll take mine wrapped in bacon.
Old Sep 11, 2016 | 04:54 PM
ofelas's Avatar
Salt water sissy.
I think I have a Cummings motor for you to buy.
I give you half goat free.
My fren.
Old Sep 11, 2016 | 05:20 PM
Rick 12v CTD's Avatar
sounds like the injection pump. How many miles are on it?
Just as a precautionary measure I would verify voltage and a strong connection at the FSS
Old Sep 11, 2016 | 05:41 PM
j.fonder's Avatar
sorry, i should've added what happened this morning.
Went out to the truck to continue wrenching. tried to start it and nothing. didn't hear the FSS clicking as usual, so i pulled it out. Plunger was separated from the solenoid and stuck in the pump, had to yank it out with pliers. so i left it gutted and reinstalled. had to bleed injector lines and got it running again. thought "hmm, maybe that was somehow it?" took it for a test drive and same old same old. started cutting out on me after about 10-15 minutes of driving. wanted to stall out on my a few times on the way home, had to keep the RPM's up a bit to keep it from stalling at stop lights. limped it home and now contemplating pulling the pump off.
motor has less than 150k on it.
Old Sep 11, 2016 | 10:11 PM
deere country's Avatar
Mileage on an engine has absolutely nothing to do with wether or not an injection pump could fail. Keep in mind that engine is 25 years old and if the pump is original to the engine it's done well.
Even if the truck odometer it came from read 150,000 miles, unless you know the trucks complete history from rolling off the assembly line chances are more likley than not that the odometer either quit working, works sometimes, has been replaced at least once, or who knows is out of a ford truck.
I guess what I am getting at is if your timing hasn't been compromised your pump is in need of repair.
Old Sep 12, 2016 | 01:14 PM
It's not going to be timing related anyways. If it were timing related the problem wouldn't come and go like it does.
He's either sucking air or has an injection issue. And he did mention his fuel pressure maintains fine and he ran a hose from the lift pump to a bucket of fuel too so it stands to reason that it's not likely a supply problem
You are right that mileage often doesn't necessarily tell the whole story but it is still helpful to know.
the VE44 is pretty well known to be bad if it runs semi ok until everything is warmed up and then starts giving troubles like he is experiencing.
Old Sep 12, 2016 | 03:52 PM
gyman98's Avatar
I would say either timing or air infiltration. Take a bucket of cold water with you and go for a drive, when it acts up dump the water on and drive away. See what happens
Old Sep 12, 2016 | 04:58 PM
That's a good idea....
I still think it could be the large springs inside the IP...
Old Sep 13, 2016 | 12:53 AM
DodgeFreak's Avatar
Springs usually cause it to miss continually not run good for 10-15 mins then act up when warm. Sounds more like a worn H&R.
mkozlows
Jun 17, 2011 06:25 PM
jrv15
Apr 20, 2010 11:15 AM
dwa
Oct 31, 2009 05:26 PM
Bean
35
Jun 2, 2008 04:28 AM
Clucker
Apr 26, 2005 05:42 PM
