I`m at wits end
Old Jun 17, 2011 | 10:36 AM
mkozlows's Avatar
I`m at wits end
1999 QC 2500. I have had electrical problems since the day I bought this jalopy. Seat belts will not unlock, stereo controls have never worked, Wipers only work on continuous, no intermitant function. Dome light has never worked.
I was told that I needed a new CTM... After replacing it with a new unit nothing changed. I then replaced the clock spring, again no change.
Does ayone have any ideas what might be causing these issues. I am at the end of my rope, I recieved a seat belt ticket because I got tired of having to disconnect the battery every two days.
Any ideas would be appreciated.
Old Jun 17, 2011 | 12:52 PM
rebal's Avatar
wipers probably need a new control modual seat belts might need lub ,dome light might be a few things .like bad bulb bad door jam switch ,bad head light switch,radio might just be bad the truck has a few years on it now
Old Jun 17, 2011 | 01:59 PM
mkozlows's Avatar
I have checked all of those, everything checks out (Well except the Radio controls)
Old Jun 17, 2011 | 02:05 PM
swordfish's Avatar
Have you checked all your grounds? Check out this link for the wiper issue...might save you some money...
Wiper Fix
Old Jun 17, 2011 | 03:36 PM
mkozlows's Avatar
Wiper Fix
Thank you swordfish. I will see what happens.
Old Jun 17, 2011 | 04:59 PM
67HotRod's Avatar
I second the checking of the grounds. Check the body to frame connections and check the connectors/plugs for corrosion.
Old Jun 17, 2011 | 05:09 PM
Polaraco's Avatar
Old Mopar Aficionado Extraordinaire
Actually, it sounds like you have a fault in a ground
Was the harness molested?
Old Jun 17, 2011 | 06:25 PM
southerman's Avatar
i had a 1st gen. did the same thing ended up being a bad ground. the shop added a ground everything worked after that.
bobinyelm
27
Nov 24, 2014 04:49 PM
jrv15
Apr 20, 2010 11:15 AM
dwa
Oct 31, 2009 05:26 PM
Bean
35
Jun 2, 2008 04:28 AM
Clucker
Apr 26, 2005 05:42 PM
