Fuel in AFC after Denny T pin installed?
Old Jul 12, 2009 | 11:51 AM
Jer12377's Avatar
From: North Haven,CT "Living in occupied teritory" & Barton,VT
Question Fuel in AFC after Denny T pin installed?
I went to install a 3200gov spring today and when I took off the AFC cover and removed the diaphragm and pin. I noticed fuel all over the pin and some under the diaphragm.
Is this normal?
When I took the old pin out it still had some grease on it that I assume was there from the factory. When I put the pin in on Friday I smeared a little grease on the Denny pin and it is now washed off. Thanks for any info.
Old Jul 12, 2009 | 12:02 PM
archer39's Avatar
the pin that rides on the fuel pin sometimes gets over extended with the aftermarket pins. I don't remember what guys were doing for a solution but yes there has been many people with the same problem. Here is a write up in the sticky on how to fix the leak.
Old Jul 12, 2009 | 12:19 PM
cougar's Avatar
Gunk builds up on the pin. When it has to travel further than it use too, that gunks hits the o-ring. Sometimes the pin will clean its self off and re seal. Other times, the pin will have to come out and be cleaned, then a new o-ring installed.
Instructions
https://www.dieseltruckresource.com/...d.php?t=153154
Old Jul 12, 2009 | 01:05 PM
Jer12377's Avatar
Thanks for the link guys. Now I need to figure out if I should finish the install of the 3200 spring or get the kit and do it all at the same time.
Old Jul 12, 2009 | 06:38 PM
cougar's Avatar
That is what my plan is. I got them both at the same time. You have to take the AFC housing off any way, why not replace the o-rings and seals at the same time? It's not because I'm lazy because I am, I just hate taking something apart twice.
Old Jul 12, 2009 | 11:27 PM
Jer12377's Avatar
You wouldn't happen to know how much that kit costs? There is one local diesel shop where I am and I'd swear they have 200% mark up.
Old Jul 13, 2009 | 04:15 AM
Jim Lane's Avatar
Post
You will need a Bosch Gasket Kit #DGK-121
I don't really remember exactly but it should be under $20.00.
There was someone here who was replacing the pin with a longer pin made from a drill bit or at least was talking about it.
Jim
Old Jul 13, 2009 | 10:22 AM
Jer12377's Avatar
Jim
Thanks for the info, The local Cummings dealer turned me to the Bosch dealer they deal with. The kit was $19.95 plus a few bucks for delivery, and same day delivery. I am going to tackle this after work today.
Old Jul 14, 2009 | 11:27 AM
cougar's Avatar
The kit and 3200rpm spring cost me $40 mailed to AK from TN. The local Bosch dealer won't sell parts.
Old Jul 14, 2009 | 01:25 PM
mwlu711's Avatar
cummings?????????
[QUOTE=Jer12377;2525660]Thanks for the info, The local Cummings dealer
is that one of those new fangeld european enginge companies?i have never seen a cummings lots of peopla talk about them though i hear their great i mite try one some time.but till i do i im just gana stick with my cummins.lol sorry i couldnt resist.
Old Jul 14, 2009 | 02:39 PM
I wasn't gonna say anything but you went there mwlu711.
Old Jul 14, 2009 | 03:30 PM
dzl_damon's Avatar
also a great search technique to find the good Cummins on ebay no one has bid on cause it's spelled wrong and they couldn't find it!! It's how I found my Utility truck as a matter of fact and got it wicked cheap.
"Deisel" is another social de-engineering tactic!
gaberichison
Dec 21, 2014 12:21 PM
92smokin blacky
May 19, 2009 06:58 PM
The_Head
Feb 20, 2009 10:23 PM
92 Bob
Feb 8, 2009 02:12 PM
ups132
Apr 4, 2008 02:18 PM
