Front Suspension Upgrade
Old Oct 4, 2014 | 04:11 PM
  #181
mknittle's Avatar
Originally Posted by Nughuffer
Its too dark. I can't see the truck at all. Where am I?
turn the light on!
Old Oct 5, 2014 | 02:30 PM
  #182
dan123dbl's Avatar
I'm thinking about trying their new 3 leaf springs : http://customsuspension.com/products...em-height-pair
What do you guys think?
Old Oct 5, 2014 | 05:40 PM
  #183
Originally Posted by bobva
Whats your problem??? Buyer beware WT?
I got the parabolic springs on my truck I love them they ride on my truck. My truck is a clubcab. My Friends Std cab with the parabolic spring rides even better.
I strongly believe that's cause of wheelbase..... Std cab trucks are less bouncy than CC trucks brand new off the line!!!!!!!!!!!!!!!!!
You got a 4D long box that truck never came off the line with 4WD... Do you know why??? I'll tell you It's because they bounced too much.
NO off the shelf leaf spring has ever been built for that wheelbase truck
You know I had never thought of it that way. The fact that the factory may have made a long box 4wd crew and discovered in testing that it was way too bouncy.
I have no problem modifying the set-up I have now, with the mods that sevnt300 came up with.
Old Oct 8, 2014 | 10:38 AM
  #184
dan123dbl's Avatar
Anyone else think these look kind of goofy? Why would the leafs be all the same length at one end?
Old Oct 8, 2014 | 10:54 AM
  #185
j_martin's Avatar
It all depends on what you want. Those are high rate springs that hold the load starting from 0. Ride like a buckboard, deflect less under load.
The reason leaves are shorter in the stack is to provide a progressive rate. The heavier the load, the stiffer the spring. One drawback is that it can overload the main leaf at the ends if it's designed wrong.
Old Oct 8, 2014 | 11:00 AM
  #186
dan123dbl's Avatar
On their site they have "3 LEAF DESIGN - "THESE SPRINGS RIDES SOFTER THEN OUR 2 LEAF DESIGN""
Kind of hesitant about buying them but I might go have a look after work. The least they could do is double check their grammar
Old Oct 8, 2014 | 11:06 AM
  #187
bobva's Avatar
TC what shocks do you got on?
Im guessing bisteins.. they did not fit on my truck the right way
I got some skyjackers on my truck cause they fit right. https://www.dieseltruckresource.com/...t308959p2.html
Old Oct 8, 2014 | 11:23 AM
  #188
bobva's Avatar
thrashingcows
the only road that I dont like driving my truck on is the underside of the http://en.wikipedia.org/wiki/Ship_Canal_Bridge. that bridge makes my outback hop
You drive truck for a living you so know how bad the I5 is going thought Seattle mainly southbound in between the convention center and boeing field.
I fly down that chunk of hiway 70 plus drinking coffee. truck is empty no load.
My springs that I bought from CS are stock not hacked in any way and never will be.
Old Oct 8, 2014 | 12:49 PM
  #189
j_martin's Avatar
Whatever the rate (softness or hardness) it'll be the same from no load to the blocks.
Most of us have variable loads, ie empty or a cord of oak. We need springs that change characteristics with load, thus multi-leaf progressive springs.
Old Oct 9, 2014 | 05:58 AM
  #190
comotionman's Avatar
I am sorry guys but I think parabolic springs are a poor design. The latest 3 leaf pack shown in pic above is proof positive.
Old Oct 9, 2014 | 07:37 AM
  #191
mknittle's Avatar
I agree. I hear more bad than good about them. there must be a "sweet spot"(wheel base weight) though, as they work well for some people.
Old Oct 9, 2014 | 09:12 AM
  #192
bobva's Avatar
Then explain to me why Im 100% happy with mine.
Could it be I put the Right shocks on my truck.
Old Oct 9, 2014 | 09:25 AM
  #193
mknittle's Avatar
Could be any combination of things shocks ,wheelbase, weight.
For me they are too hit and miss to justify the cost.
Old Oct 9, 2014 | 09:32 AM
  #194
bobva's Avatar
There no hit and miss when you use the right shocks
The cheese eaters that are complaining about the PB springs fail to mention the shocks the are using.
Old Oct 9, 2014 | 09:42 AM
  #195
mknittle's Avatar
I still am not convinced. I can get a better ride using a known combination for half the price. that leaves me with more money for other parts.
