Front end noises-where is the source?
Is your truck still running the original front springs?
If so, look at the rear shackles on the front springs to see how much clearance you have between the sping eye and the bottom of the frame rail.
Started to happen, I'm thinking, ever since I installed dual shock steering stabilizers. What I don't see, though, are scrape marks on any of the stabilizer hardware/brackets. What were you getting at on the springs? What am I checking for in clearances and what is spec?
Angel, Charlie, Dawg, and 92...Thanks for all the advice. I will inspect and do the cheapest things 1st like the grease and so forth. Since we are on a partial subject on bushings, the prevous owner handed me a box full of new bushings (kit) for the entire truck. Never done bushing swaps before. Where would they get swapped at, and are they a remove and replace thing? No dangers that I should know about? What about preparatory work like jacking up the truck and chocking the rear tires...are those required to do to swap bushings out? Are you supposed to insert grease inside the bushings before you slide the bolts through? Help, coach!
The_Head
Jan 27, 2009 09:01 PM
NoSparkplugs
Dec 7, 2006 09:57 PM
Sux 2B urTurbo
23
Aug 14, 2004 11:56 PM
