front end
Old Mar 19, 2005 | 11:07 PM
loch's Avatar
front end
I noticed a pooping in my front end when i turn sharp, iv looked at other threads concerning cracking, anyone have bit of info on this?
Old Mar 19, 2005 | 11:34 PM
edwinsmith's Avatar
You mean popping? I have a pop/gring in my front end as well when I turn sharply and go over bumps or curbs. I think it's a design flaw in Dodges. I had a van that did it as well. I think it's the tie rod binding and isn't really harmful unless you do it a lot. I just ignore it for the most part since my truch drives beautifully and everything is tight.
Edwin
Old Mar 19, 2005 | 11:47 PM
rebal's Avatar
my u bolts will do that when the tires get worn down on the 4x4 but had a 77 2wd that would do it and after I put new rubber body pucks in it stopped
Old Mar 20, 2005 | 03:12 AM
TexasHardcore's Avatar
My truck does it when turning sharp , and turning over a bump, like a driveway or something. You can feel it pop under the floorboard. I hate it.
Old Mar 20, 2005 | 10:14 AM
rebal's Avatar
I hear it, and passangers feel it on the floor
Old Mar 20, 2005 | 10:31 AM
Blowndodge's Avatar
Turning left into my driveway from the street or going into a parking lot I hear a loud grinding poping sound that even my passengers ask me, "what the heck is that?". Done that since new. Even backing out of my driveway with the wheel turned left does it.
Brad
Old Mar 20, 2005 | 10:37 AM
rebal's Avatar
Brad ,could it be the turn stop screw on the A arm ? my .02
Robert
Old Mar 20, 2005 | 04:47 PM
Bingo! Dodge says to grease 'em to reduce noise.
Old Mar 20, 2005 | 05:22 PM
Blowndodge's Avatar
Turn stop screw went right by me! What am I looking for on the A arm? Guess I'll have that done when I get my 7226S springs in?
Brad
Old Mar 20, 2005 | 05:59 PM
C Pierce's Avatar
my strut rods did that before i replaced the bushings
Old Mar 20, 2005 | 06:39 PM
They are bolts that hit the spindles at full lock. If there's no lube they make nasty noises when the suspension moves with the wheel cranked over. Mine are dry too, but I know what the noise is and ignore it.
Old Mar 21, 2005 | 04:32 PM
SmokinFive9 4x4's Avatar
Check your body mounts as mentioned before. mine had a tiny crack when I turned before, now with the body lift it sounds like a shotgun (to me anyways). I've got new body mounts setting in the garage waiting and the body lift's coming off, and just as a sidenote, NEVER put on a body lift, it's a waste of time and money. by far the worst thing I ever did to my truck.
1999blackcloud
Jan 26, 2010 08:52 AM
big jimmy
Jan 29, 2006 11:17 AM
shoffs30
Sep 13, 2005 09:57 PM
Gordonville
Apr 18, 2005 09:45 AM
royta
Jul 13, 2004 06:54 PM
